Mitsubishi WS-65807 65 in. Rear Projection Television
Problem for Mitsubishi WS-65807 65 in. Rear Projection Television
My 2001 ws 65807 still has great picture but the
By mikey3401 on Oct 25, 2009
My 2001 ws 65807 still has great picture but the remote seems to have gone south so I cant get to advanced convergence adjustment feature. The set has been moved twice since I originally purchased it. Is there an aftermarket remote that performs all of the functions of the original or would the mfr possibly still one available for an 8 yr old set?
Solution #1
posted on Oct 25, 2009
Not Rated)
SD Tech
Rank: Guru  Televisions & Videos  Expert
Rating: 97%, 907 votes
PART number for the original remote is :290P10310
Almost any Mitsubishi remote made in the last 8 years will operate this set--even the ones for the DLP type sets--stay away from universal remotes as most of the time the will do only the basic functions---I have talked to customers of mine who found used ones at swap meets etc for very little money---I would bet you can still get the remote from Mitsubishi--if I remember most of these are around 40 dollars from them.
Another idea is have someone at a TV shop look at your old remote--if they know what they are doing they can test it( I have a laminated card with a strip on it--point the remote at the card and the strip should light up when you press any button)
If if cannot be fixed---Try either Mitsubishi or I have seen a lot of these remotes for sale on Ebay.
Let me know if this helps you-----I am here to help people.
SD TECH
Comments:
Oct 25, 2009
- By the way--if the set turns out to have a convergence problem and will not adjust--let me know--I have fixed hundreds of these sets with convergence problems and have step by step start to finish instructions on how to do it yourself--
If this turns out to be the case let me know.
Regards, sd tech
Was this helpful?
Yes
No
Popular Solutions for Mitsubishi WS-65807 65 in.
Questions and Unsolved Problems for Mitsubishi WS-65807 65 in.
Do you recommend Mitsubishi WS-65807 65 in. Rear Projection Television?
Answer
Answer
all colors are good except for the blue green! things that are blue looks green
Answer
When I turn on my WS-65807 it clicks on then about 4 secs later it turns off. No pic comes up before... (More)
Answer
I have a Mitsubishi WS-65807 and I'm getting 1-2 code on the diagnostic. The TV won't power up.... (More)
Answer
My Mitsubishi ws-65807 has what appears to be a red overlap. Pretty much the same screen twice. Any... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Mitsubishi WS-65807 65 in....:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
