Question about Sony Handycam DCR-TRV460 Digital Camcorder
Can't get Video onto Television..Can get Audio.
My girlfriend's Handycam worked fine a few months ago when we used it to watch something on TV using the A/V jack. Yesterday we could get audio, but no video and figured it was the cable. I went out and bought a similar cable (one input into the camcorder, three jacks into V, A right, and A left) with the same results. I tried the Video 1(back of tv) and Video 2 (front of tv) options on my new Toshiba. The video screen on the handycam itself works fine. Just won't transfer to the TV. Any help would be greatly appreciated.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Does this cable have a mini jack that plugs into the camcorder?
Thanks for getting back five months later. I ended up buying a new Monster cable that worked just fine for like $40.
Posted on Jun 11, 2008
My Sony HDR-UX10 is not recording audio
The in built microphone is faulty, use an external mic, it will work, if dirt inside the mic jack use contact cleaning spray, then check, the inner mic will also work.
Jan 31, 2016 | Sony Video Cameras
Hitachi 43F300 TV no audio or video probs
Could you have bumped the wrong button on the remote? Make sure the TV's input is set to where the DVD is connected.
murf427
Aug 04, 2012 | Hitachi 43F300 43" Rear Projection...
How can I transfer the video from a Sony Handycam CCD-TR416 to CD or DVD
How to Transfer video from Sony Handycam CCD-TR416 to DVD - You need a DVD Recorder / Player, connected to your TV. Then using the audio / video cables from your camcorder, connect them to the TV as well. Turn your TV on so that you can watch the video out from your camcorder and then select the record button on your DVD Recorder / Player. Then you have a DVD that can be watched in any DVD Player or Computer with out any compression. This is how I transfer my camcorder tapes to DVD.
Aug 10, 2010 | Sony Handycam CCD-TR416 Camcorder
Dont know how to play a tape from camcorder onto my tv
just insert the tape in camera and connect yellow to yellow port in camera and audio is white and red on the other side follow the color code on tv back panel or front if u have and put ur tv into AV mode and then play back ur camera tape using playback mode look out for switch with play icont on it to select the play mode in camera u are set watch it on tv u want anything else i am here to help u
pls rate me FIXYA for help
Apr 14, 2009 | Sony Handycam CCD-TRV57 Camcorder
No sound on my 32'' Insignia LCD HDTV
Try to unplug the tv for a few seconds and then plug it back in again.
Jan 28, 2009 | Insignia LCDTV26 26 in. Television
ILO-26HD Audio & Video
I have a ilo 26 lcd tv with built in hdtv tuner and I have a red line down the center of the screen that started today. t
Feb 06, 2008 | iLO 2600 Television
I have a question? Do you move your Television frequently, OR do you unplug it frequently when it's not in use? I have found that doing either or both of those things can bring on problems, especially audio problems.
I've had the disappearing sound problem twice with my Element FLX-2610. This latest time I was stumped because the full scan didn't resolve the problem. And of course, the sparse manual that comes with the TV contains no troubleshooting advice at all.
But I did find a suggestion on another sveral other sites: Reset the TV. You might have a small reset button (like you would find on a DSL modem) somewhere on your TV but there is a manual way to do it two. Whichever way you do, MAKE SURE to disconnect every single device (yep, it's a pain) and UNPLUG the TV before doing this.
To reset with a reset button, disconnect devices and unplug the TV. Depress the reset button for 5 seconds. Reconnect devices, then plug in the TV.
Manual Procedure:
Disconnect all devices
Unplug the Television
Using the on/off button on the Television (NOT on the remote), depress and hold the button for 5 seconds.
Reconnect the devices, then plug in the TV.
Unless something has shorted out or burned up inside, this resetting, as a last resort, should fix the audio problem. Worked like a charm for me!
Good Luck!
Nena
Jan 19, 2008 | Insignia IS-LCDTV32 32 in. Television
Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Oct 15, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Old video games
 Dear friend try to change your cables if you are using regular A/V cables, you know the white/red/yellow, use a S-video cable and or maybe try to change the Video Input settings in your TV by going in the setup menu and look for the settings that will suit your console the best, most TVs comes with adjustable Video settings that ranges from Normal, Theater or Cinema, Video Game etc. pick the one that works with your systems. If none of this works try to contact the place you bought the TV and ask them for warranty repair or exchange. good luck!
Oct 10, 2007 | LG RU-27LZ50C 27 in. HD-Ready LCD...
DCR-TRV130 - not playing back
The head may be dirty, clean it with a cleaning cassete, playing using the cleaning cassete will clean the dirty head.
May 18, 2007 | Sony Handycam DCR-TRV130 Digital Camcorder
Sony Handycam DCR-TRV460 Digital Camcorder Logo
48 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
