Question about Mitsubishi WD-52528 52" Television
Tv does not turn on. Timer light blinks
The green timer light blinks for for about 30 seconds then nothing, repeats every minute or so but never turns on,
  • elgina Apr 17, 2009
    timer light blinks for 30 seconds then stops then does it again and tv does not turn on
    The tv does not run error codes
    Genius:
  • 1,153 Answers
First check error codes to do this search threads or goto ctechnicians.com
Posted on Dec 31, 2007
Entrance light on Lift Master garage door opener won't stay on when door is opened ?
Light Feature
Activate the Light Feature
  1. Close the garage door.
  2. Start with the garage door opener lights "ON".
  3. Press and hold the light button for 10 seconds. (Upon pressing the light button, the lights will immediately turn off and come on 10 seconds later.)
Deactivate the Light Feature
  2. Start with the garage door opener lights "OFF".
  3. Press and hold the light button for 10 seconds. (Upon pressing the light button, the lights will immediately turn on and go off 10 seconds later.)
Light Timer
Press the Light button to turn the opener light on or off. It will not control the opener lights when the door is in motion. If you turn it on and then activate the opener, the light will remain on for 4-1/2 minutes. Press again to turn it off sooner. The 4-1/2 minute interval can be changed to 1-1/2, 2-1/2, or 3-1/2 minutes as follows:
  1. Press and hold the Lock button until the light blinks (about 10 seconds).
  2. A single blink indicates that the timer is reset to 1-1/2 minutes.
  3. Repeat the procedure and the light will blink twice, resetting the timer to 2-1/2 minutes.
  4. Repeat again for a 3-1/2 minute interval, etc., up to a maximum of four blinks and 4-1/2 minutes.
Oct 20, 2017 | Building Materials
Toshiba 50HP95 timer/Rex light blinking green. Tv wont turn back on.
place to begin if you are able is examine the power board for puffed up caps and or voltages coming into the board and out of it.
Aug 27, 2012 | Toshiba 50HP95 50 in. Plasma Television
Sony kv-27v40 standby/timer blinks 5 times
Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Apr 23, 2012 | Sony KV-27V40 27" TV
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
I have a Sony KDS-R50XBR1 that has no picture. When I turn on the TV, the green Power/Standby LED light blinks for about 30 seconds, then turns red and blinks five times. The Power/Standby LED repeats...
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen A2 slightly.
Jan 19, 2011 | Sony KDSR50XBR1 50" Projection HDTV
Hi, i have here a mitsubishi WD-57733. once the unit is switch ON, green LED light and a few seconds the status LED light then shuts off. I think light engines good since i just replaced a new lamp.
hello i've just checked the manual for here is some information
None TV is powered off. Normal operation.
Green TV is powered on. Normal operation.
Green 1. TV just plugged into AC outlet.
Wait until blinking stops before turning on (approximately 1
minute). Normal operation.
2. AC just restored after power failure.
3. TV Rebooting after System Reset was
used.
4. TV Rebooting after power fluctuation
or receiving abnormal digital signals
from digital channel, or digital device.
5. You have begun the procedure to
update software from an authorized
flash memory device.
For detailed information, see the instructions that accompany
the authorized software update. IMPORTANT: Do not
use unauthorized software at any time.
Green TV just powered off and lamp is
cooling.
Starts to blink 30 seconds after turning off TV. TV can be turned
on before blinking starts or after blinking stops, but not while the
indicator is blinking. Normal operation. hope it helps regards shaun
Green TV powered off and auto-on timer is set. Normal operation. TV can be turned on at any time.
Dec 06, 2010 | Mitsubishi Televison & Video
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Turn on the TV and only Timer light is on , no sound & picture
after holding down the menu and device the led will blink a two digit error code such as 3 blinks pause then 4 blinks then repeat that sequence a couple of times. Need that blink code to help let you know whats going on. The 34 code means lamp abnormality which translates to the power Pwb capacitors have most likely failed.
Jan 23, 2009 | Mitsubishi WD-52525 52" Rear Projection...
press the menu and input/device buttons both in together on the front of the set and hold for 5 seconds and then see if the set blinks a number of blink pauses and then blinks another number such as 2 blink pause 2 blinks which would be a 22 caode. It then repeats that code.
Jan 21, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Have you tried to hold the menu and input/device buttons on the front panel in together for 5 seconds to see if it will blink a two digit error code? Try that then let me know the code that the led blinked
Aug 05, 2008 | Mitsubishi WD-52528 52" Television
Mitsubishi WD-52528 52" Television Logo
366 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
