Question about Onkyo TX-SR605 Receiver
Unable to get HDMI signal into TV
I am unable to route my HDMI signal through the receiver. My DVD and cable works fine directly to the TV but not via the receiver. I am not sure what setting needs to be changed on the receiver for it to work.
Please help!
  • 3 more comments
  • Anonymous Dec 31, 2007
    Don't know about the DVD player (ours works fine with this receiver), but I do know the Motorola cable box we have won't send a signal to anything but the TV. This is a known problem with the cable box, and apparently can't be fixed.
  • hektor Jan 04, 2008
    I connected a ONKYO Tx-SR605 Receiver to a Mitsubishi 73” DLP TV. My connections were as follows.
    My DirecTV HD box and a Sony Blu-Ray were connected to the ONKYO receiver’s HDMI 1 & 2 inputs. The ONKYO receiver HDMI output was then connected to the Mitsubishi TV HDMI input #1. I did have the ONKYO receiver HDMI output to the TV turned on.
    I also have an Xbox connected by way of the Mitsubishi TV HDMI #2 input, and a Optical Digital cable connected for the Xbox to the ONKYO receiver Optical input #1. This connection was necessary because the ONKYO receiver only has two HDMI inputs.
    This connection worked for about 40 days. Any time we wanted to watch TV, we just needed to be on the TV’s input #1, then switch to the TV’s input #2 when we wanted to play the Xbox. And like I said, this worked great for 40 days.
    One day when we had the TV’s set to input #2 because we were playing the Xbox. Then we wanted to watch a movie so we tries to switch back to the TV’s input #1 to get the signal from the ONKYO receiver the was connected to the TV’s HDMI input #1.
    What had happened id the TV for some reason lost the setup for the ONKYO receiver. It was like it was never their. I tried to do any thing the book had on setting up the connection but The only way I got it to work was to hit the reset button in the front of the TV. After I got it to work again and then I would turn the TV and then back on, or if I were to change the TV’s HDMI input #2 to play the Xbox, and then tried to switch back to the TV’s HDMI #1 it would be lost again.
    Also when I was trouble shooting this issue, I was able to get the TV working with the ONKYO receiver by unplugging the HDMI cable, and then plugging it back into a different HDMI input on the TV. But I would still have the same trouble and the connection would be lost.
    I got the TV to work, but what I had to do is do a factory reset on the TV the connect everything directly to the TV’s HDMI inputs, and then connect the ONKYO receiver by way of a Coax cable to the Digit input of the ONKYO receiver.
    How can I get it to work again using the ONKYO receiver as the hub instead of the TV? Connected the way I have it now, I’m not taking advantage of the ONKYO receiver’s HDMI inputs as well as it’s 7.1 capabilities.
    I think I may have either turned something on or off in either the TV or the receiver, and it is creating the problem. Besides video and sound, it seems they are creating systems so HDMI connected components can control each other by way of the HDMI connection.
    Could something like this be causing the problem? I did try different HDMI cables.
  • WESTMORELAND Jan 07, 2008
  • Gorbash Feb 09, 2008
    I have the issue where my setup has been working for about 6-8 months and now experiencing similar problems.
    Tried to turn it on one evening and there was no image.
    Denon DVD - HDMI1 + Coax1 (Denon DVD apparently needs a different source for sound)
    Sky+ HD - HDMI2
    No picture from either but sound from DVD. (looks like the HDMI ports)
    I've taken the HDMI cables out of the Onkyo and connected them directly to the TV and they work fine. I've also switched them around and reconfigured the Onkyo settings
    Am I missing something or is my Onkyo needing a replacement ? :(
    Is there a way to reset the factory defaults on the Onkyo TX-SR605
  • AyersTobin Feb 26, 2008
    DVD works fine through cables not HDMI because DVD player does not have HDMI adaptation
    TV is the problem....HDMI cable is running from HD Cable box to reciever input 1 and and another HDMI cable is running from the reciever HDMI out to the Sharp Aquos TV in the input 4 HDMI slot....I can hear volume but i do not recieve any picture.....i did the setup but it does not give me a choice of input4 just input 1 and 2, but HDMI on my TV is Input 4 ...
    Problem Solver:
  • 5 Answers
I have the same receiver and TV that I just bought 2 weeks ago.I cannot get the video to work with the HDMI cables. I have sound though.I Have the TV connected from HDMI3 to OUT on the receiver and the cable box connected to IN1. I am sometimes able to get the picture to show up by "tricking" the TV and connecting another HDMI wire, but when I turn off the TV I lose it again. The problem is the TV, I connected the receiver to another TV and it worked fine with video and sound. I sometimes get an error message from the TV " HDMI switching through the AV Receiver is not supported". I do not know what this means or how to overcome it. I have spent hours and tried every combination of settings possible but until I can break this error message, what can I do to overcome this problem?
Posted on Feb 17, 2008
In the setup guide, try going to the HDMI option where you turn the montior out to "on" for the HDMI output. I don't believe that the receiver comes with the HDMI out already turned on...
Posted on Jan 01, 2008
Cant get tv audio through receiver directly (without satallite, Game, DVD connection)
If your TV doesn't support audio return channel (ARC, which is your TV audio routed back to the receiver through the same HDMI cable), you then need to connect your television audio-out to your Onkyo TV audio input, using a digital cable or an analog one according to the connections on the back of your TV. If you use a digital connection (optical or coaxial), make sure you have the proper digital port assigned to TV on the onkyo I/O assign menu/digital inputs.
In case your TV does support ARC, you need to activate it in the Onkyo's hardware/HDMI setup menu, either by turning on HDMI control (tv or receiver control each other via cable), or by turning ARC on (you'd probably need to activate ARC on your TV as well).
Hope this help,
Jan 03, 2013 | Onkyo TX-NR609
Hi I have a STR-DN1000 - My HD box connects to it via HDMI and optical cable. Then I have a PS3 connected via HDMI only. Then just an HDMI cable going from the amp to the TV. When I switch inputs between...
Your connections are fine the issue here is with the onboard processor.
HDMI is a great connector ONLY because it simplifies wiring.
The "concept" was to give consumers a simple way to connect their components while allowing devices to "communicate" to each other by being able to send control signals through the same cable.
HDMI is a digital format which has advantages but unfortunately these signals must be processed by the receiver, the problem that arises is that dvd players, video games etc. generally do not encounter issues when connected directly to a television but once you route that signal into the receiver well that a whole new ballgame there. (you are adding processes to the signal)
The delay and popping are caused by the processor making the needed adjustments and "reading' and converting the signal for display.
Personally I use HDMI but I also connect the optical AND component cables, Why? well for starts you can "upconvert" to HDMI but not "downconvert" so if you need a analog signal for a dvd burner s-vhs recorder or ? the HDMI signal can't be converted to a lower quality (for copyright reasons)
If you are not using the receiver for video switching or for multi room you will get a better picture by bypassing its video capabilities.
On low or mid line receivers such as your Sony I would run the hdmi's to your HD monitor and run the optical cable to your receiver.
Yes this will mean you will have to switch 2 inputs when changing sources (tv and then receiver) but should give you quicker video processing and better picture.
Now I don't want you or anyone to think "oh my Sony sucks" as its not entirely Sony's fault HDMI through ANY receiver brings issues I have a $2000 Denon and the HDMI sucks on that too!
I did write an extensive article/post on HDMI processing about a year ago its somewhere on this site.
Hope that helps
Sep 22, 2010 | Sony STRDN1000 71 Channels Receiver
Direct TV satellite to TV connection issue
hi cable from the wall into the box then a cable from the box into the tv or hdmi cable from the box to the tv thanks
Jun 13, 2017 | Toshiba Televison & Video
Sony STR-DE925 auto-decode has worked fine for years. All DVD/PS3/Cable is attached to TV via HDMI and inbound audio from HDTV is optical fiber (TOSLINK). Up until today, this has worked perfectly, i.e.,...
OK, so with more troubleshooting, I was able to eliminate the problem with my DE925. It was actually the Vizio HDTV that was causing the problem, as I decided to route the optical audio from my DVD and PS3 directly to the same TOSLINK port on the DE925 and auto-decode worked. It was not the fiber-op cables either. This HDTV was a less-expensive 720p 32" model anyway, so I am not too concerned with the optical out working on it as I can run up to four TOSLINK connections in to the receiver.
Jan 02, 2010 | Sony STR-DE925
I just bought a yamaha rx-v365 receiver and hooked to my cable box via a hdmi and optic audio cable. this is working fine but i cant get a dvd player to work via a component and coax audio cable. neither...
Make sure that the DVD player is connected into the correct inputs on the receiver and that the receiver also has the correct input selected to play. If your TV also has component video inputs it is best to connect the player directly to the TV. Otherwise, make sure you have the TV connected to the receiver via component video out.
Nov 25, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Mar 08, 2017 | Electronics - Others
Denon Avr-588 setup
nice gear. Without further information, i am going to describe the best setup possible with your equipment.
1. make sure the speakers are connected to the receiver and you can hear sound out of it
2. connect cable box to receiver via hdmi to receiver.Choose cable on the receiver or video1 etc. (if you are not using hdmi cables post annd i will walk uthruogh a non hdmi process)
3. connect a hdmi cable from thee receiver monitor output area to the tv hdmi input
4. connect the dvd player hdmi to the input of the receiver
to watch select the tv av mode to line up with the receiver and choose video1 for tv and dvd to watch dvds on the receiver.
good luck
Jan 03, 2008 | Denon AVR588 Receiver
New home theater setup- no signal at tv using onkyo tx=sr605
Could well be the quality of your cables. if you have high end cables the consult a service agent. if you have the cables that came with the products, go and get some better ones.
Nov 04, 2007 | Onkyo TX-SR605 Receiver
Onkyo TX-SR605 Receiver Logo
843 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
