Phillips 170b monitor not working
Hi, My monitor went black last. If I turn it off and on again it lights up so you can see whats on the screen but then goes black. I've tried it through the USB connection and the same thing happens. I've tried just turning it on without it connected to the computer at all and the same thing happens. Any help would be very much appreciated.
  • 1 more comment
  • Anonymous Jun 24, 2008
    I have the same problem with my Philips 170S4 and need an awnser...
  • Anonymous Aug 02, 2008
    Exactly the same problem here. Phillips 170B Monitor about two years old. Lights up for no more than 2 seconds then goes blank. Switch on/off and exactly the same thing. I suspect than the screen goes really dim rather than switching off because sometimes I can see the screen image very faintly.
  • clocksmurf Nov 23, 2008
    my phillips 170s also shuts down in 2 secs. The capacitor between the two stepup transformers had the lid raising. try to change the cap but with no result :( can hear a high pitch sound from the psu when i turn it on, but as soon the light dissaperars (on the screen) the sound stops with a small click. have measured the 5 and 12v going to the video board and these are ok
Most monitors come with a 3 year warranty....if you are within this warranty SEND IT BACK. This problem is usually down to a faulty transceiver. Easy to replace but be sure to disconnect electricity as you can get a fatal shock
hope this helps
Jeremy
www.bluejayspc.co.uk
Posted on Oct 02, 2008
Posted on Aug 02, 2008
This is most likely a power inverter problem & they are not cheap to exchange/repair. Buying a new monitor is probobly your best bet.
Posted on Nov 04, 2008
My HP vs19e Monitor went black, when I turn it off...
guest, If monitor vs19e acts same when connected to different "known good" pc then try this site for info: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ How old is this model? When was last time it worked correctly? 12fixlouie
May 19, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
Blank Screen
Common problem in monitors are bad caps in the power supply, that is the first place to check, look for bad caps with bulging top/bottom, see example of failed VIEWSONIC monitors due to bad caps here (worst case will be bad lamps): http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can help you further.
Feb 06, 2010 | ViewSonic VG2230WM LCD Monitor
Viewsonic VG2230wm 22 Blank screen
Look for bad caps in the power supply first, see example of failed VIEWSONIC monitors due to bad caps here: http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can guide you furhter.
Feb 06, 2010 | Relisys RLT1720 17" LCD Monitor
No sound from headset plugged into monitor
From the manual I found, this model does NOT support ANY audio connections.
http://www.p4c.philips.com/files/1/170b1a/170b1a_dfu_aen.pdf
170B Product Features
- 17" color LCD monitor with excellent display performance.
- Dual input-accepts both DVI Digital and VGA Analog input.
- Advanced AUTO adjustment automatically optimizes picture quality.
- Wide viewing angle technology.
- 7.1 (181mm) small footpring with full detachable cables.
- USB Bay for upgrade to USB Hub.
- Optional protective cover to prevent LCD panel damage.
- Standard VESA mounting holes and optional tilt/swivel Wall Mount Kit.
But if yours does have these ports, I would suggest they are not for a headset, but for connection to the _PC_. I would suggest your model monitor has built in speakers, and the green port is the INPUT from the PC Speaker output. The pink goes back to the PC from the MIC which is built into the screen.
Apr 21, 2009 | Computers & Internet
Monitor
sound like the power supply or the monitor bulb is going.
try the monitor on another PC if you can get one, if it works, then you have to find ou the manufature of the video card and get the driver.
Nov 05, 2008 | Philips 170B4MG 17" LCD Monitor
Screen black
if monitor light is on, check the connecting data cable if it is ok then consult a technician.
Oct 28, 2008 | Computers & Internet
Mag lcd monitor
probably capacytor problem in the mainboard, take it to the lab it will be cheaper then buying new one
May 06, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Computer says disk boot failure when I turn it on.
hard drive failed or you have a cd in or floppy in the drive.
Jan 07, 2008 | Philips 170B5CB 17" LCD Monitor
Computers & Internet Logo
1,395 people viewed this question
Alun Cox
David Payne
David Payne
