Question about LG Flatron L1750S 17" LCD Monitor
L1750s 17" the power indicator led is blinking and no picture
    Problem Solver:
  • 16 Answers
This problem is showing when the main PCB of the monitor failed. contact the LG service provider in your area. Here is the link to get the service center info
http://www.lgservice.com/
Posted on Feb 09, 2008
My LG Flatron L1750S has just glowing white screen and no on screen setup menu either.
That is a common symptom of a failure of the filter capacitors on the power supply board. When the filter capacitors go out the backlight can get power so there is light but the control board is not powered up so you get no picture. You can rebuild the board and bring the unit back to full working condition by replacing the defective parts. Here is a link to information showing what capacitors you will need to get to do the rebuild.
www.ccl-la.com/catalog/product_info.php?products_id=246
And here is a picture of what the AIP-0108 power supply board looks like
I hope this helps,
BuddyMc
Nov 27, 2012 | LG Flatron L1750S 17" LCD Monitor
No power in monitor
First check for a LED indicator? if there is one is it changing when you turn on your monitor? if there is changing light then the problem might be on the power supply or maybe on the LCD lamp. To check the power supply check for a defective fuse a defective fuse has no reading on multimeter and the o.k has 000 reading. the LCD lamp power supply can be converted into different power supply. hope this may help you.
Jul 27, 2011 | LG Flatron L1750S 17" LCD Monitor
How do I turn it on
Hello.
To power on the Gateway VX750, press the power button on the front. The power button has 3 sides with a "G" in the middle.
The LED indicates the power status of the monitor.
  • Not lit - The monitor is turned off or does not have power connected.
  • Blinks one time and then goes off - The LED blinks one time when the monitor's power cord is plugged into an AC outlet to indicate that power is detected.
  • Lit solid blue - The monitor is turned on and active.
  • Blinking blue - The monitor is in power saving mode. Before entering power saving mode, a message briefly appears.
Hope this helps.
Aug 12, 2010 | Gateway VX750 (Black, Platinum) 17" CRT...
LG Flatron - green power led blinks twice
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 21, 2010 | LG Flatron L1750S 17" LCD Monitor
My dell monitor turns on for 2 seconds then goes black and the green light blinks orange
I assume that you already try this monitor on another PC to verify that the problem is in the monitor, in this case you need to open it up and inspect the fuse, transitors, solder connections on the power/inverter board, see failed Dell monitors here for guide: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 23, 2010 | Dell E173FP 17" LCD Monitor
THE POWER LED (GREEN) IS BLINKING CONTINUOUSLY
LG 700E monitor's power LED blinking continueously and there is no display solutin ........
May 30, 2009 | LG Flatron F700B 17" CRT Monitor
LG Flatron L1750S LCD won't display anything...
To your concern, a couple of suggestions:
  • if you could try again a reputable electronics service center/shop, pls mention for them to look at the CCF (cold cathode florescent) lamps, the inverter and/or the main board;
  • the blinking light is significant, it could indicate loss of video signal or internal protection kicking in;
  • possibly heat related, check for any of the capacitors bulging or leaking.
If they would reference a service manual or a schematic diagram, pls relay that it is chassis CL-82 for an LG L1750S. Foremost to check would be for the presence of both the 12 and 5 volts,.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 22, 2008 | LG Flatron L1750S 17" LCD Monitor
LG Flatron L1750S 17" LCD Monitor Logo
563 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
