Panasonic PT-51HX41 51 in. Rear Projection Television
Problem for Panasonic PT-51HX41 51 in. Rear Projection Television
On my panasanic I have a red arch on the screen as
By greyman1969 on Oct 25, 2009
On my panasanic I have a red arch on the screen as you are looking at it. What would cuase that?
Solution #1
posted on Oct 25, 2009
Not Rated)
SD Tech
Rank: Guru  Panasonic Televisions & Videos  Expert
Rating: 97%, 1155 votes
If you have gone into the customer menu and CONVERGENCE is skewed and will not adjust:
One or both of the two STK-392-110 convergence chips that this set uses are bad.
The chips are about 2 1 /2 inches wide by 1 1/2 inches tall and are black in color. They are mounted on metal heat sinks with fins and are side by side--they will have the Stk-392-110 number printed on them in white letters.
If you locate them take a good look at all the light blue resistors in front of them--most are marked 2.2 ohms---look for any that are white or discolored in the middle---if you find one or more YOU HAVE FOUND YOUR PROBLEM.
BOTH chips and any bad resistors need to be replaced and the set adjusted. If you can do this repair you can save a lot of money as you can buy both chips (a pair) on Ebay for about 12 dollars plus shipping.
I have start to finish instructions for this repair on this type of set. Keep in mind, I am not allowed to post MY email address here for you.
If you cannot do this repair yourself, shop around your area--most shops charge 300-400 for this kind of repair--I do them here for 200-250 and have done hundreds of them.
If they say it has to go to the shop--keep looking as any good tech can do this repair in your home in about 1 hour.
If you have any questions or need advice reply to this posting here OR check out all my many solutions here for more information concerning what I have told you.
I am here to help people.
Regards, SD TECH
Was this helpful?
Yes
No
Popular Solutions for Panasonic PT-51HX41 51 in.
Questions and Unsolved Problems for Panasonic PT-51HX41 51 in.
Do you recommend Panasonic PT-51HX41 51 in. Rear Projection Television?
Answer
Answer
I have a PT-51HX41E when I turn it on and no matter which input I use I have red, green, blue and... (More)
Answer
Panasonic tv pt-51hx42f shuts itself off and power light flashes 3 times.
Answer
tv shuts off on it's own. I have to unplug it and plug it back in to gett it to turn back on. What... (More)
Answer
I have a pt-56hxpf panasonic when i turn on no pic the power button just flashes what could be the... (More)
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in , PA
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
