Question about Kenmore 73952 Gas Dryer
Kenmore gas dryer 110 70602990
Hi, my dryer will not heat up, I cleaned out the vent the igniter is glowing and its getting enough of gas. Can you help me figure out the problem
  • Anonymous Feb 12, 2008
    it work fine for 5 min then no heat .i cleand lint any one know thanx.
    Master:
  • 619 Answers
The heat thermostat are open/need to replace
Posted on Jan 01, 2008
My kenmore gas dryer works for 5 minutes then control panel flashs and won't heat th cloths
GOD IS GOOD !!!!
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
Sep 21, 2014 | Kenmore Sears Kenmore Clothes Dryer Flame...
I have a kenmore Dryer 110.76932690. Motor runs fine. Glow bar ignitor does not light. Flame doesn't come on. Changed Internal Bias Operating Thermostat still doesn't ignite. What could be other
Thermal Fuse
Air Flow and Heat
Warning
GOD IS GOOD !!!! AND THAT IS WHY MY ADVICE IS FREE
Aug 30, 2014 | Dryers
Why is my Kenmore 500 series gas dryer won't heat up, no flame.
Thermal Fuse
Air Flow and Heat
Warning
Aug 21, 2014 | Kenmore Dryers
Kenmore advantage gas dryer
Thermal Fuse
Air Flow and Heat
Warning
Aug 10, 2014 | Kenmore Dryers
Kenmore gas dryer series 500 won't heat
Thermal Fuse
Air Flow and Heat
Warning
Jul 04, 2014 | Kenmore Elite HE4 Electric Dryer
How do i fix my kenmore gas dryer model 87673100, will not heat up
Thermal Fuse
Air Flow and Heat
Warning
Jun 14, 2014 | Kenmore 63942 Dryer
My Kenmore elite gas dryer sometimes starts and sometimes doesnt ?
Thermal Fuse
Air Flow and Heat
Warning
Jun 02, 2014 | Kenmore 74892 Gas Dryer
Kenmore Gas Dryer ignites then stops heating after ten minutes.
If the glow bar comes back on and the gas does not light,replace the gas valve coils. If the ignitor does not come back on,replace the flame sensor.
Sep 01, 2009 | Kenmore Dryers
My kenmore model 70 wont heat. I replaced the coils, and gas sensor. the unit has been thoroughly cleaned. the igniter is heating up, the gas will light, then goes out a few seconds later. the unit is a...
Hi, Make sure the 4" vent is clean al the way outside. Make sure the vent hood in the wall is open. It sounds like the heat is short cycling do to poor air flow.
If the vent does not appear to be an issue, Watch the ignition while running and see if the ignitor glows later in the cycle and shuts down before the flame ignites. If this happens, you will need to change the coils on top of the gas valve. Please let me know if this helps you at all or if I can assist you further.
Thanks
Vic
Jul 27, 2009 | Kenmore 63942 Dryer
Dryer will not heat up
Take off the cover from the front, bottom of the dryer. You should see the burners. Take this opportunity to clean lint from the area. Start the dryer and watch this area. You should see the igniter begin to glow. If it doesn't, you could have gotten a bad replacement. If it does glow, either the gas coils are out or the temperature sensor is out. You could check them if you had an ohmmeter or replace them both as they are relatively inexpensive. I have experienced gas coils that will get so weak that even though they pass the ohm test, they still won't open with the correct voltage applied.
Jul 08, 2009 | Kenmore 73952 Gas Dryer
Kenmore 73952 Gas Dryer Logo
341 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
