Question about Sony Ericsson K800i Cellular Phone
Backlight Hello, I've had my phone for 12 months now and all of a sudden the backlight refuses to go out, thus draining my battery. Any ideas? kpd
All you need to do is to replace you display or whole keypad for that to work.
Posted on Dec 31, 2007
Hi I have a Acer aspire 9410 (9414wlsmi) 17 screen. The problem is that i have no backlight at all, i've bought a new screen + new inverter/backlight driver + new cable but it did'nt help i have...
The inverter/backlight combination isn't the whole picture. The inverter powers the backlight, but the inverter is controlled by a signal commonly called "Brite-On", which comes from the motherboard. If the "Bright -On" signal from the motherboard is missing,then the inverter (and thus the backlight) won't work. The problem you are having is on the motherboard. here's a link to a datasheet of such a device:
http://pdf1.alldatasheet.com/datasheet-pdf/view/245132/FAIRCHILD/FAN7317.html
May 15, 2011 | Acer Aspire 3690 (LX.AFL0J.044) PC...
Nokia n79 prototype software issue
Does the phone have an IMEI starting with "0044..."? If so, the update service won't do anything at all with it...
Jul 02, 2009 | Nokia N79 Cellular Phone
17 month old set; Picture gone. Direst TV repairman says it's the backlight bulb. Others say it's a Board.
it might be inverter board it is not backlight bulb according to my expertise bcoz once it goes off it dont come back
but u see inverter and CCFL backlight bulb failing symptoms are so same that u cant simply distinguish but i am sure u have one of these two problems inverter is more chance
Kindly rate me well
Regards
Zohail
May 23, 2009 | Vizio VX42L 42 in. LCD TV
Backlight not turning on when phone is turned on (Razr)
There is a small cable, inside the phone, near the hinge, that can come loose or unplugged. You should have this checked out by someone who can service it. For them it's a simple procedure of reinserting the cable fully.
Aug 03, 2008 | Motorola Mobility RAZR V3
Battery suddenly will not charge.
the charger has gone bad; get a new one at sonyericsson.com
Mar 05, 2008 | Sony Ericsson Z610i Cellular Phone
Keyboard Backlight
you need to take the phone to a mobile service center and have them replaced the flexcable for you.
Feb 05, 2008 | LG KG800 Cellular Phone
Display backlight problem
i have the same problem, i thought it completely blacked out, but i realized it was just the main backlight. i can see it if i hold a flashlight to it, but i tried everything to fix it, and ive had no luck.
Sep 21, 2007 | LG VX8300 Cellular Phone
Series Back Light
It is possible that by holding the power button down too long, that you turned off the backlight. When you hold down the power button, a menu eventually comes up with "Backlight Off" highlighted. The easiest way to undo this, is to simply do a soft reset. Or, you can hold down the power button again, and "Backlight On" will be highlighted (if there's enough ambient light you can see this message); just tap it, and the backlight will come on again. Also check out your backlight settings by tapping: [Start][Settings]tab[System][Backlight] the tab [Battery Power] should be highlighted; adjust as desired. Next tap the tab [External Power]; adjust as desired. Finally, tap the tab [Brightness] and make sure the sliders are high enough.
Sep 07, 2005 | HP iPAQ H6300 Pocket PC
Sony Ericsson K800i Cellular Phone Logo
70 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
