GE GSS22JF Side by Side Refrigerator
Problem for GE GSS22JF Side by Side Refrigerator
Freezer works great but fridge temp too high, not
By supertruck89 on Oct 24, 2009
freezer works great but fridge temp too high, not cooling properly
Solution #1
posted on Oct 25, 2009
Not Rated)
mgprice
Rank: Guru  GE Refrigerators  Expert
Rating: 95%, 499 votes
Hi, With the information you supplied I’m going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself.
This is going to be one of three problems with your refrigerator, 1st thing to do is remove shelf’s and panel in the back of the Freezer. You may see ice build up on the evaporator, don't worry get a hair dryer and melt the ice.
Next locate the wires for the defrost heater and using a multi-meter/ohms meter test the heater for continuity (it should read infinite) if the defrost heater is bad replace it.
This is what a typical defrost heater looks like:
If the heater is good test the defrost thermostat. This should normally be done when the evaporator is still covered with ice since it will only activate at 40f - 50f depending on the thermostat. When tested with the ohms meter at below 40f it will read infinite. It is normally clipped to the upper right of the evaporator and look something like this:
The next possible problem could be the defrost timer. If you have tested the heater and thermostat and they have tested good next find the defrost timer, If your refrigerator has a mechanical one it will either be located inside the control panel in the fridge or behind the panel below the doors. Once you have located it advance the dial until you hear a click. This will initiate the defrost cycle. If your heater begins to get hot this will tell you that your timer has stalled and needs to be replaced. A typical mechanical timer looks like this:
If your refrigerator has a digital defrost timer you should locate the tech sheet. Normally you can find this behind the panel under the doors. It will tell you how to initiate a manual defrost cycle. As before if the heater gets hot you will have to replace the mother board normally located behind a panel at the rear of your refrigerator.
If your fridge is warm and there is no build up of frost/ice on the back panel inside the freezer then you problem is most likely going to be the evaporator fan, have you heard the fan running in the past few hours? if you are not sure pull the panel out to where you can see fan and watch it over the space of an hour to see if it turns. If you don’t see it turning replace the motor. This is what a typical evaporator fan looks like:
Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck & thanks for using Fixya! Mike
Was this helpful?
Yes
No
Solution #2
Not Rated)
Sea Breeze
Rating: 90%, 790 votes
That is the first signs of a defrost problem. Most likely the defrost heater and defrost thermostat are the problem. If the rear wall of the freezer is showing a line of frost building now would be a good time to unplug, remove rear panel in freezer and use a hair dryer to remove the ice from the evaporator until you are able to see the defrost heater at the bottom of evaporator. When you are ready and get to that point let me know, Sea Breeze
Comments:
Oct 25, 2009
- You may need to contact me here for more help as I am not informed that you responded. http://seabreeze.fixya.com or my contact information on top right=> HERE Thanks, Sea Breeze
Oct 25, 2009
- MGPRICE the GE GSS22JF does not have a defrost timer.The defrost heater is part number Click Here=> WR51X10101 and the defrost thermostat is part number is WR50X10068 Hofully the motherboard is OK because the defrost timer is part of the motherboard. Sea Breeze
Was this helpful?
Yes
No
Popular Solutions for GE GSS22JF Side by Side
Questions and Unsolved Problems for GE GSS22JF Side by Side
Do you recommend GE GSS22JF Side by Side Refrigerator?
Answer
Answer
I have a GE side by side ref. model # GSS22JFMC WW that is not cooling. A few months ago I replaced... (More)
Answer
my g.e. tbx 21tkc fridge, only gets 20 degrees in the freezer and 50 in the fridge, i replaced the... (More)
Answer
How much did it cost to have the motherboard, heater, and thermostat replaced for the GSS22UFPA... (More)
Answer
GE model GSS22JEPH Have to turn water off at valve behind appliance.
Describe your Refrigerators problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerator Experts
Top Refrigerator Repairmen
in Colton, CA
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(650) 616-9292
Refrigeration Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
