Question about Lexmark JetPrinter X1185 All-In-One InkJet
Printer Spooler service!
I am trying to install my printer but I keep getting a message that says "The printer spooler service is not running". Can you please help me fix my problem? Thank you!
spooler service not working
  • 5 more comments
  • Anonymous Dec 31, 2007
    my print service is not into the list of servers.
    I can't make active.
  • Jennifer Cornett
    Jennifer Cornett Apr 17, 2008
    That is the same thing mine says "printer spooler stopped" I have tried numerous times to restart it and it states can't start. I do not know what to do someone please help.
  • DaDa1 Jun 01, 2008
    I continue to get this message - The printer spooler service is not running. I deleted the software like I was recommended to do and then tried re- downloading but it will not let me do it.
  • Anonymous Jul 24, 2008
  • rvann Aug 26, 2008
    One of our users is getting an error that says: "the printer spooler service
    is not running." Thanks in advance for assistance with this problem.
    -Ron V.
  • Anonymous Aug 27, 2008
    lexmark x1185 print spool services is not running comes up on my screen each time i try to add printer
  • Anonymous Feb 03, 2009
    printer spooler not working, lexmark 1185
Go here.
Posted on Jun 27, 2008
ohms
  • 1879 Answers
SOURCE: Printer Spooler service!
click on the start button -> run -> type services.msc then hit OK
look for Printer Spooler and make it run
Posted on Jan 03, 2008
  • 202 Answers
hi,buddy
you have to start printer spooler by this.
click "start btn"
click on "run"
write here "services.msc"
double click on "print spooler"
select status type "automatic"
than click on "start"
now install your printer.
Posted on Jul 27, 2008
hemantraj
  • 638 Answers
to make spooling work its necessary to make it work
this is the procedure .if you do this it will work properly. till it is not done it will just ignore printing
1)click the start in the left sice of your computer screen
2)go to control pannel
3)click performance and maintainence
4)click system
5)click data execution prevention
6)turn on DEP for essential windows program and services only.
7)click the spooling services a tick mark sign will appear beside that means it has enabled.
now your printer will work properly.
pls do rate the solution if helped. thanks.
Posted on Aug 16, 2008
  • 5 Answers
That doesnt work for me as soon as i go to install the printer again, the window pops up and says the spooler is not working causing the download to quit before it starts....
Posted on Sep 13, 2008
I am trying to install my printer but I keep getting a message that says "The printer spooler service is not...
Posted on Oct 21, 2008
The print spooler service is not running.
Reinstall the printer drivers will shore it up quickly the spooler has to do with the printer so do that and you should be fine.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 23, 2009 | HP OfficeJet 4215 All-In-One InkJet...
"Error 1068 Could not start the Printer Spooler on local Computer"
I appreciate the opportunity to help you. Try the following:
Check dependency services on Print Spooler
1.Click "Start", input "services.msc" (without quotation marks) to Start Search bar and press "Enter".
2.Double click the “Print Spooler” service.
3.Choose “Dependencies” Tab and remember the services name.
4.In the service list window, find the dependency services and try to start them.
5.Please try to start the “Print Spooler” service again.
See if this helps. If it does, please fill in the rating of my service to you. Thanks for using Fixya.com
Jan 27, 2009 | Office Equipment & Supplies
This will provide you with the most common default settings.
  1. Restart (reboot) your system [to assure a clean reinitialized starting point].
  2. Log on as any Windows user that has 'administrator' privileges.
  3. Open your 'Services' console [Start button > Run... > type "services.msc" (without quotes), then hit 'Enter'].
  4. Locate, then open "Print Spooler" [double-click it OR right-click it, then choose "Properties" from the context menu].
  5. Modify the settings on the "General", "Log On", and "Recovery" tabs according to the following images.
"Today's the best day of my life...and NOW you're part of it!"
Dec 11, 2008 | Lexmark E120 Laser Printer
HP Laser Jet 1018 printer problem
To start the service:
  • Go to your Control Panel -> Administrative Tools -> Services
  • Find the Printer Spooler service
  • Right click it and choose Start and wait for the service to start
To make sure it is automatically turned on the next time you run your machine:
  • Right click the Printer Spooler service and choose Properties
  • Select Automatic under Startup type and hit the Apply button
Note: You will need administrator privileges to run those steps.
Oct 26, 2008 | HP LaserJet 1018 Printer
Click on "Start, Run", type "services.msc"
On the right side of the services window, scroll down to "Print Spooler". Double-click it.
If startup type is "disabled", click the drop-down and set to "Automatic" and then click "Start". If already on automatic, click "Stop" to stop the service. Once stopped, click "Start" to restart the service.
Reboot and try again :)
Hope this helps - remember to rate!
Oct 01, 2008 | HP DeskJet 5550 InkJet Printer
1) Click the Star>Run, type in "Services.msc" in the Run dialog box.
2) A services window popup, find the service name "Print Spooler", double it and change the Service Status to "Start".
Now u can use your printer now.
YBC (/\)
Aug 04, 2008 | HP LaserJet 1018 Printer
hi,buddy
click "start btn"
click on "run"
Jul 27, 2008 | Lexmark Z645 InkJet Photo Printer
click on start ..RUN.....type cmd......type sc config spooler depend= RPCSS......click on start ..RUN......type services.msc.......look for ptrint spooler......it will be started if not then double click on print spooler and click on start.
Now try installing the printer.
May 31, 2008 | Lexmark X4270 All-In-One InkJet Printer
Dec 25, 2007 | Epson Stylus CX4600 All-In-One InkJet...
Lexmark JetPrinter X1185 All-In-One InkJet Logo
145 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
