Question about Dryers
Dryer starts, then stops, no heat
My dryer is about 6months old. I run regular loads in it, never anything like rugs, etc.. Yesterday after about 10-15min. the dryer stopped and the lights that indicate what part of the cycle it is on (dry, cool down, etc.) all blink in unison continuously until the pause/cancel button is pushed. I also noticed that it seems as though there is no heat. Please Help.
  • 1 more comment
  • erin barber
    erin barber Jan 02, 2008
    Sorry, i thought i had put it in the title the dryer is a:
    Frigidaire gas dryer
    Model # LGQ1442ES0
    Strangly enough, i cannot find any information (repair manuals, where to buy) about this dryer online except for this one site, as though it does not exist.
    Thank you for checking this post.
  • erin barber
    erin barber Jan 04, 2008
    Here is my other question, along with the no heat - the top pic, the green arrow points to the lights that continue to flash. there is now a random fast clicking coming from the dryer.... it is coming from the bottom right hand corner in the front of the dryer (see bottom pic). it sounds like what a relay would when clicking loudly.
    does that still seem like the same issue? i ran it alone last night, and it stopped, but did finish a whole load, but still did not heat, and now the clicking accompanies it.
    thank you so much
  • Anonymous Jun 07, 2008
    dryer starts to heat and about within minutes there is no heat-dryer still spinning???
  • 66 Answers
If ther is no heat you need to ck igniter. if igniter not working the gas will not be on it cost 50.00 and part # is 13439400.
Posted on Jan 02, 2008
  • sohail anjum Jan 04, 2008
    the cliking sound is igniter try to light the gas . if cloth is not drying ck the vent in the back of the dryer it need to clean.
Need model # and brand
I was drying rugs and one of the rugs got caught and the drum stopped turning. The power comes on but the dryer drum will not turn.
Hello, one possible cause of dryer drum not rotating is the rugs stuck between the drum and front panel.Secondly, maybe the dryer belt dispart.
Jul 31, 2013 | Sears Kenmore Elite Gas Dryer Front Load...
Roper dryer RAS7133RQ1 won't start
For starters, a user manual for your dryer can be found here.
Jun 02, 2008 | Dryers
Whirlpool front load dryer will not start
Does your dryer have a reset switch on the back, usually a small red button, if it does press this and ten test dryer starts again.
Dec 21, 2012 | Whirlpool Dryers
My dryer keeps running really hot and blowing the heat sensor. I have had a tec replace this part 3 times and he just replaced the board. stopped working after one load. makes a clicking noice when I hit...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Aug 24, 2010 | Whirlpool WED5900S Electric Dryer
Will not heat
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
Jul 16, 2009 | LG DLE7177 Dryer
Whirlpool Dryer won't start
You probably had been using the dryer alot today. As long as the motor was running there was enough air flow over the motor to keep it just cool enough to allow it to continue to run. When you stopped the dryer the heat tripped the thermal protector in the motor. Let it sit an hour or so and it should restart. The motor is probably coated in dryer lint, and / or the motor bearings are getting bad. If you space your drying loads out a bit you can get by for a long time without having to do anything.
Sep 16, 2008 | Dryers
Whirlpool Gas Dryer - Model LGB6200KQ1 Serial # mm2105815 Heat comes and goes. Can heat fine for a few loads then stops. Then starts again. Any ideas
Sounds like it is running Hot, Clean you venting out and make sure the weather hood outside is not blocked.
Vacuum out the lint filter area.
Your dryer also may have worn seals, how old is it? 10 to 12 years running a load a day average? it may be time for a new dryer or rebuild yours.
Jul 10, 2008 | Whirlpool Dryers
Whirlpool Electric Dryer Won't Start
Your dryer has a non-resettable "thermal safety fuse" part number 3392519 which stops the machine dead when the temperature near the heater gets too high. Typically a restricted vent system causes this so you definitely want to check that before replacing it. A failed control thermostat can also cause this so check the operating temp too.
Dec 30, 2007 | Dryers
Dryers Logo
313 people viewed this question
Top Dryers Experts
