Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hotpoint Aquarius WD420 5+5Kg
Starts wash cycle, water fills, drum rotates, starts 2nd water fill - lights 1 (Dryer high heat), light 3 (rinse hold) and light (on/off) flash repeatedly and machine drains - cancel and on/off become inoperative. Any help most appreciated
Jez
  • 3 more comments
  • Anonymous Apr 17, 2008
    Same machine, same problem. Only top two lights flashing slowly and on/off quickly.
    Allan
  • Anonymous Mar 13, 2014
    the water hasnt drained out and the lights are flashing on the front
  • Anonymous Mar 16, 2014
    mini load and on/off lights keep flashing and machine sounds like its filling up but still wont start also wont turn have to switch off the mains
  • Anonymous Mar 20, 2014
    My admiral washing machine has been working fine but this last time, it filled up with water and the red light was on that the lid was locked for over two hours so I pressed down the button to cancel the cycle but I never got the machine back on and the waters still in there since I cant drain it. no cycle is working
  • Anonymous Mar 24, 2014
    Will start to fill but then the drum wont rotate
    Power is fine have done reset and it will drain
    Master:
  • 619 Answers
The water level vacuum switch are not working , check hose might lose.
Posted on Jan 05, 2008
HOTPOINT AQUARIUS WF546 My washing started to smell so I removed the inlet filter to the pump, removed debris and cleaned the filter. Once refitted I then switched the machine back on. Now it starts a wash...
Hi, i had the same problem with this washing machine, i cleaned out the filter as you have already done & i also put soda crystals & white vinegar in the drum & washed on the hottest cycle,this cleans out all the build up. Theres no harm in trying it, hope it works for you too.
Mar 13, 2011 | Washing Machines
I have a hotpoint aquarius WF32O and when i put
is it spinning and craccleking,,carbons faulty in motor ;;will work on spin but not lower voltage wash?
change carbons,, use genuines,only
Jun 21, 2010 | Washing Machines
When i put it on a wash cycle it starts then all of a sudden the power light flashes rapidly and the rinse hold light flashes steady
Fault code F02 meaning Motor jammed / tacho detached: check motor
& module connections.. on the motor plug check that a wire hasn't become dislodged or broken...
Dec 14, 2009 | Hotpoint Aquarius WF000 Front Load Washer
My Hotpoint Aquarius WF440 fills up fine but will not move on to rinse and spin. Engineer been out and says its the heating element. He has asked me to wash on no heat until part arrives. Since then every...
I am fairly confident that the problem is entirely due to the fact that the heater is not working.
You are going to have to wait until the new heater is fitted beore being able to tell if there is another fault.
Hope this helps.
Dec 02, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius 1100 WM63. fills with water...I dont think it is heating water...rarely rotates and spins (saw it once in early stage of J prog only) seems to fill and empty but no rotate or spin....
if it fill with water then stops it is the ellement the machine first fills turns the drum then heats up the thermostat cuts in and the it emptys rinses and spins so if it does not get to temp it will stop or continue to wash forever
Jun 27, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Drum doesn't really rotate on wash cycle.
No solution, but I have the same or similar problem - bootom agitaor works, top doesn't. Also softner spots clothes during spin cycle - help - I can't afford a repairman!
May 17, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint wd440 aquarius
Not all programes fill with hot water.Try on 95 degree wash if it takes hot water ,you are dialing a prog,that does not take HOT.
Oct 31, 2008 | Hotpoint Aquarius WD63 Front Load...
Lights flashing but machine not working
hi there i would check the connections to the heater and ntc both can be found behind the lower inspection cover at the rear, UNPLUG FROM MAINS FIRST AS LIVE PARTS EXPOSSED BEHIND!!!
Feb 08, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
600 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
