Question about Sony KP-53XBR200 53" Rear Projection Television
Snowy picture in all video sources -Sony Kp53xbr200
I am getting a snowy picture in video sources on this television, the PIP looks great but full screen is snowy in all video inputs and sources even using the S-video inputs. I spoke with a Sony Technician who said I possibly need a logic board.
Do you have any suggestions and if I do need a logic board, where can I get one, I am told Sony discontinued making parts for this model.
Help
Kenny
  • 1 more comment
  • hektorolguin Jul 22, 2008
    my problem is the tv is on in only green foer 10 seconds y off only audio
  • 24money Jan 10, 2009
    My tv has snow but in TV mode only. I put a dv and nothing i get a Perfect picture. This the 2nd tv in 6 months same problem.
    first was a toshiba. I fixed the convergence and then about year later color snow lines that appear to move across the screen. Soi bring up another tv sony... fixed convergence on this tv and 3 months i have snow on this tv. i thought it was the cable... What could the problem be? The dvd works fine the tv doesn't... DVD is perfect! The snow on the tv is getting progressively worse now though. Is it time for a new tv? I'd rather not...
    2 tv s same problem... 1st tv had a convergene problem fixed it then about 4 months later these color like snow lines become visable. DVD pic is perfect, but the tv pic is snowy.
    2nd t v i fixed the convergence on it and then about 2 months later swnowy color lines come across the tv... DVD is perfect.
    The tv's were put into the same cable hookup. I exhanged the cable box thinking it was that but still sme problem.
    Any help?
  • 3 Answers
I'm working on the same problem. I posted a little about this problem under another question for the 53XBR200. From what I've learned so far with experimenting and studying the schematics is that the problem is with the BR board which is the module that handles upconverting. PIP video goes through the BM board/module. You can pull the BR board out of the set and still have the TV work as long as you keep it in PIP modes. Likewise, you can pull the BR board out, but the set will turn off if you try to go into any PIP mode. The problem with static on every input only remains in full-screen video. As you've noted, all inputs work fine as long as you remain in one of the PIP modes. It does look like the BR board is discontinued. I would like to know how to get a replacement/repair if anyone knows about this. My only hope to get this set functional again is to either force the video to bypass the BR board, or repair the BR board itself. If it's a discrete component on the BR board (capacitor, resistor, transistor) then it might be possible to salvage a repair. If it's one of the upconverting chips, then we might be SOL. I've tried to jump the video signals around the BR board, but this didn't work and the picture looked distorted. I think the problem with this idea is that the video processor might be expecting 480p/960i video and by bypassing the upconverter I'm sending 480i video into the video processor. I'm going pursue this idea some more as it might be the only way to salvage the set from the trash bin.
Posted on Jan 02, 2008
  • Rev Engineer Jan 04, 2008
    Looks like the signal coming out of the upconverter chip on the BR board is very noisy. I suspect the DAC inside this chip is toast. The chip is not available as well as the BR board. This set may very well be headed to the trash bin. Anyone needs parts from my set to fix other problems?
My samsung plasma tv powers on has sound and a picture, but is snowy, and coloring is slightly off. I have opened the tv to check for bulging caps and have found no obvious culprits. what next?
Snowy pics are not the symptom of bulging caps.
you must mention what type of source produces 'snowy' pics.
have you tried with other sources and ports ?
I recommend, you test out the following.
- DVD with Component connection
- HDR or STB with HDMI
- TV/Antenna
Aug 15, 2016 | Samsung Televison & Video
SONY rear projection TV - Whites have started looking "snowy"
This is your Picture tubes getting very weak.( low in emission ) You have three in there and I guarantee they are no longer available so I would start thinking about investing in a new set, but use that one until you can't stand it anymore.
May 28, 2009 | Sony KP-53XBR200 53" Rear Projection...
Snowy Picture
Hey that boy is still under warranty don't fool around get it fixed by SONY
and it still may be a broken coax just enough to cause your trouble but call them ASAP
Nov 14, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Snowy black & white picture
Sounds like the problem is back again
Feb 08, 2018 | Televison & Video
Old Sony KPR-53EX35
If you have snowy picture on this TV set, the problem is not your high voltage transformer,
The defective part is more likely the tuner or the IF section of the TV.
I would suggest to use a video source from a DVD player ot VCR and connect the audio & video output to the audio & video input on the TV. Do not forget to select video 1 or 2 on the TV.
Hope this helps.
Feb 15, 2008 | Televison & Video
Akai PDP4294 - Snowy, pink & green picture
It is most likely a problem with the tuner, I would contact the place you purchased it or your nearest repair shop.
Feb 07, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai leisure 2111 TV
try to check the video section, the diode and the capacitor.also the transistor>
Sep 19, 2007 | Akai LCT2060 Television
Rear projection snow
Bad primary tuner==can be replaced,or==by-pass by using video inputs.
Aug 26, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
FUZZY (SNOWY) PICTURE
When you say you have tried all the inputs you are not clear if you mean tuner, vcr, dvd, aux, etc. If you are talking about only the cable input it sounds like you have a bad tuner. To obtain picture in picture there are 2 tuners in your set. This would explain why the small picture is ok while the main picture is bad. You should be able to swap the signals (see your ops manual). Try this. If the snow moves the one tuner is bad. If you have put other signals in (besides cable)such as dvd then the problem is in the matrix circuitry where the two signals merge. Either problem should be easy for a good tech to solve and not cost a whole lot.
Jun 01, 2006 | Sony KP-53XBR200 53" Rear Projection...
Sony KP-53XBR200 53" Rear Projection Television Logo
239 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
