In order to pair a BlackBerry smartphone with a Bluetooth enabled device (e.g. a Bluetooth enabled headset), the Bluetooth enabled device must be in pairing mode. Most Bluetooth enabled devices are not set to pairing mode by default. Refer to your Bluetooth enabled device manual for instructions on how to set the Bluetooth enabled device to pairing mode.
To pair the BlackBerry smartphone with a Bluetooth enabled device, complete the following steps:
1) On the BlackBerry smartphone, click Options > Bluetooth. If you cannot find the Bluetooth option,
2) Open the menu and select Add Device. The Select Device list appears and lists Bluetooth enabled devices that are in range and available to be paired. Note: Only BlackBerry smartphones enabled with Bluetooth technology that are in range and in pairing mode will appear in the available Select Device list.
3) Select the Bluetooth enabled device with which you are pairing. The Enter passkey dialog appears. 4) Type the passkey to authenticate the Bluetooth enabled device. Most Bluetooth enabled devices contain a hard coded passkey. See your Bluetooth enabled device manual for the passkey. Note: 0000 is the universal passkey for pairing any Bluetooth enabled device with a BlackBerry smartphone. Note: Once a Bluetooth enabled device is paired, it appears in the Paired Devices list. The Bluetooth enabled device will no longer appear in the Select Device list.
Bluetooth devices are manufacturer specific. Please refer user manual for instructions on how to pair with other devices.
My Storm 1 will not ring. I have checked the ringtones and I can hear that ... I have read this is a...
(More)
My Storm 1 will not ring. I have checked the ringtones and I can hear that ... I have read this is a problem for others out there too! Any ideas other than another trip back to a Verizon store?? I do not have any apps downloaded and am not listening to the radio...
In certain areas of the city (Miami) , I cannot make or receive calls with my BBStorm2, I get the...
(More)
In certain areas of the city (Miami) , I cannot make or receive calls with my BBStorm2, I get the message NO CIRCUITS/CHANNELS AVAILABLE I inserted the same TMobile SIM Card into a Nokia phone and works OK I inserted a DIGITEL SIM Card from Venezuela (In the US the carrier is TMobile) into my BBStorm 2 and it's no go The same Digitel Sim Card from Venezuela works fine in an iPHONE I have a new prepayed TMobile Sim card and my BBStorm2 is brand new and factory unblocked Hope this is clear enough ...... Thanks
