Question about Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher
No water but dishwasher "runs"
My dishwasher is built in, how can I check for blockage, or leak?
I had this problem and fixed it by turning the breaker off and then back on again.
Posted on Jun 02, 2008
Dishwasher runs but gets no water...
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. Hope this helps... Please post back for any further assistance.
Daniel
Jan 31, 2011 | Maytag 24 in. MDB5651A Built-in Dishwasher
There is water in the base pan and I am unable to access the pan.
tip the dishwasher back this will reset it then check for leaks or blockages
Jun 16, 2010 | Asko D3251HDSS Stainless Steel Built-in...
I have F2 on the LED and the machine keeps running
tilt machine back to reset (water in flood pan).check for leaks and blockages
Jun 12, 2010 | Asko D1976 Built-in Dishwasher
I bought my bosch dishwasher just over a year ago and it is not working at the moment because there a red light on the say to check water
flow sesor problem, blockage in drain pump, or a leak all will cause check water light to come on i suspect a blockage as your appliance is new.
Jan 09, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
It runs but the water is not coming into the
Check connection under sink to ensure sediment is not blocking inflow. You will need unplug, shut off water valve, then disconnect hose from water source and check for blockage due to buildup of minerals/hard water. Make certain first that flexible dishwasher intake hose is not kinked..
Nov 27, 2009 | Miele Slimline G832SCi Built-in Dishwasher
LE error code
check you inlet and outlet water hoses, check for leaks and blockages
Jun 29, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Leaks while running
The water at the bottom is normal if you open it during the cycle. Leak means you need to replace the L-shaped black, molded gasket that is in the lower left or right of your door opening. Replacement is easy - requires no tools. Part can be purchased for about $10 each at Sears parts department.
Sep 07, 2008 | GE Nautilus 24" Built-in Dishwasher
Water not going through spray arms
possible you have a leak and the bottom tray has water in it. tilt the machine back to 45deg and see if water runs out of the back. if it does, after putting upright, the machine will work - then find the leak!!
May 05, 2008 | Neff 24 in. S5443X2 Built-in Dishwasher
E1 Error on LG Dishwasher (LD-2040WH)
Maybe the blockage is somewhere else. How about removing all the trays from the dishwasher, in other words, empty it from all racks and dishes and try it again
Oct 14, 2007 | Whirlpool 24 in. DU940QWD Built-in...
Dishwasher holding water
Have you checked your pipes at the gully trap end? Perhaps there is a blockage?
Oct 03, 2007 | Maytag MDB7100AWB Dishwasher
Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher Logo
139 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
