"No Active Mixer Device installed".....The Sound and Audio issue of Windows.....the infamous issue being faced by many PC/Laptop/Notebook users all over the world....on clicking the volume control icon in the task bar near the clock.....or....Sound and Audio Devices Grayed Out in the Control Panel
Guys....the solution's very simple....This is a sure shot solution...101% guarantee...Just do this...
Go to Device Manager, select Sound, Audio and Games Ctlr expand (+) press the plus sign, go one by one on all those that show a speaker image...select each one by one and right click, and if it has the "uninstall" option...just uninstall. Dont do anything further....just shut down pc/laptop
Then...u need to go into system BIOS
1 - Start PC/Laptop...press DEL or F1/F2/Insert/Home key...this selection of key to go into BIOS depends upon ur type of PC in some Del key works in some F1/F2 key works to go into BIOS....you need to do this before the WindowsXP screen appears....get into BIOS...
2 - Scroll/go to On Board Peripherals...press enter...next screen....
3 Look for
A- "On Board audio"
B- "AC97 audio" or any thing that says "Audio"
C- "Look for anything that says "MIDI" with some numbers 301,205 etc in [ ]
just Disable all the above by using PgUP PGDN key Press F10 and chose Yes to save the setting in BIOS or use Save and Exit in BIOS
Let WinXP load...go to Device Manager...go to Sound Audio and Games Controller...check all those that you uninstalled earlier if they RE-Appear...It should NOT......Re-appear.....if it does then do the above process once more.
U are now all set for the next move....
U need to spend just 1$ to buy this product on Ebay...you can buy any similar product of your choice but it must have the audio and mic output ports like this one has...and must be able to connect to your USB port of your PC/Laptop
This below image and product name is only for your info, you can buy any such similar product available in your area....but it's must have the Audio and Mic output ports like the one on the image below and must be able to connect to your PC/Laptops USB ports...
"USB 2.0 Mic Speaker 5.1 Audio Sound Card ADAPTER #9340"
You can Google it and locate it where you can buy...
Connect it to a USB port, connect your speakers/mic to the correct audio/mic slots in this device....WinXP will auto install this hardware and you will get back your Volume Control Icon...and all functions will work in Control Panel (Sound and audio Devices)...
Click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question / exclamation? ! mark or a red X Right click to reinstall drivers
If your computer came with a motherboard disk the drivers could be on it
or you might download slimdrivers.
Rather doing a driver hunt
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
Note: it will find all of your outdated drivers
This is a free driver solutions
which will automatically search for and find the correct driver
You will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue
updating each driver free then restart once all of the drivers have been updated.
It might take some time being free
also
http://download.cnet.com/2000-20_4.html
Just type in what you want or need be specific you might have to try a few times to get it right.
Tick in either the all software or the windows software box.
IE: motherboard name sound drivers
http://download.cnet.com/drivers-for-free/3000-18512_4-75548155.html
Windows XP/2003/Vista/Server 2008/7/8 free drivers
http://download.cnet.com/drivermax/3000-18513_4-10572602.html
Windows 2000/XP/Vista/7/8 free driver program
hope it helps
