Question about Casio Exilim EX-S600 Digital Camera
LCD damage My camera lcd got damaged in Miami last week.  I am looking for the cause - how did it get damaged?  I want to repair it but don't want to let it happen again. For a picture of what the damage looks similar to see photo under Step 1: http://digitalcamerarepair.googlepages.com/casioex-s600
  • Anonymous Jan 09, 2008
    Hi my camera fell down while still in the protective case and the lcd cracked. Can this be fixed or should I be thinking about buying a new camera?
  • 667 Answers
The picture shown in your provided link says impact damage. It does not take much of a bump to crack an LCD display like that.
Fitted cases aren't always the best storage for camera gear. I use a larger bag even for my smaller cameras and center the display in the middle off the case, away from the sides.
There are after market clip-on screen protectors that do provide an extra layer.
Posted on Dec 31, 2007
How can i nikon coolpix s80 damage lcd repair
look on amazon for an lcd screen, sometimes you can buy just the part and replace it yourself.
Apr 11, 2014 | Cameras
I have a Canon A560 camera. It takes pictures and I can download them to my computer OK. But the LCD screen is black, I don't see any display at all. Pushing the display button does no good.It got...
If your LCD doesn't light up then it's either the backlight or the LCD, you can open up the camera and check the cables before buying any parts. Some LCD screens come with the backlight, some don't; not sure if this one does or not.
IF it was water damage, you probably have corrosion on the main PCB and won't be able to fix it without replacing the board... open it up and check for corrosion!
Hope this helps.
Thomas
Owner, Darntoothysam.com Digital Camera Repair
Jul 11, 2011 | Canon PowerShot A560 Digital Camera
Lcd monitor is cracked and displays nothing. Should I just junk the whole thing or can i replace the lcd monitor cheaply???
No need to junk the whole thing just contact your nearest Authorized Olympus service center and they can fix the LCD screen with a genuine one in less than 150 USD.PLEASE DON'T TRY TO OPEN IT OR REPAIR BY YOURSELF as it can can cause severe damage to high end mechanics.
May 29, 2011 | Olympus Camedia E-20N Digital Camera
Part of the screen is cracked, the image is as well, Im in Miami how much will that be to be repaired
UNFORTUNATELY THIS FAULT CANT BE REPAIRED THE WHOLE LCD SCREEN NEEDS TO BE REPLACED CONTACT YOUR HOUSE AND CONTENT INSURANCE COMPANY IF IT BROKEN BY ACCIDENT THEY WILL COVER IT.
Sep 07, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Last winter I dropped my Canon FS100, and the LCD screen would only display black or a grey strobe in camera mode. After a week of what seemed to be repeated attempts to reboot, it "healed" itself! Now a...
It might be that she damaged the lens where you just got it slightly wet. damaged the lens or the CCD that receives the image itself. it might not be repairable at all, If its a case of water damage remove all power sources from it and use a hair dryer on low for a while to dry it out " make sure the screen itself does not heat up to much and focus on the lens. You may have to replace the camera or contact a repair person. I myself give any repair a try and most things with a little luck can be saved.
Mar 28, 2010 | Canon FS100 Flash Media Camcorder
The screen of my blue samsung s860 is black when i turn the camera on, it fell in water and now won't work.
if the device has fallen into water then chances are that the camera is damaged, you could leave it to dry out, but this could be up to a week, don't try to dry it with heat as you could damage the camera further, if it still doesn't work then the LCD has been damaged beyond economical repair and is has to be taken into a repair shop
hope this helps
kind regards
Nov 18, 2008 | Computers & Internet
Nokia n72
It maybe the board on the cel that is damaged or the LCD screen. If it is still in warranty, contact the retailer for replacement or service.
Oct 17, 2008 | Nokia N72 Cellular Phone
Disassembling camera
Hi pantherdave:
The premium Assistance plan will work, if the one you are asking knows the problem.
No, all the money does not just go to just the owners of the site. Each EXPERT or the one who solves the problem will get a portion of the amount.
As to your problem. I do not know that camera specifically, how ever, taking apart the camera may not help you at all , anyway.
The reason is that if any kind of camera, including digital cameras, that the mechanical parts can be damaged beyond repair, and could only be good for parts. First, what is not working?
I have had cameras which I know had been dropped, and they were only good for parts to fix others.
Next, the internal parts of the lens are very sensitive to damage. The parts are very small, and can be damaged or the lens can be thrown off track by impact. When a digital camera has had an impact, then the camera should be tested to see what is working, if anything. If nothing turns on, even though the batteries are in, then it cannot be tested, and is good only for parts.
Many times, I have found that the impact damaged the LCD, and could not be detected easily. Even though I looked at the LCD with the camera on, I did not detect the LCD damage. I only saw it when I examined it very closely. A damaged LCD may cause some cameras to not turn on at all, since it needs the LCD to complete the circuits. Some cameras will turn on even though the LCD is taken out, and may work through the USB connection, or video connector.
One thing to remember with any digital camera or any small instrument such as this is that it is extremely important to remember where each screw came from. If a longer screw is put back in some cameras, it can lead to shorting out a circuit or causing the camera not to turn on at all.
Some system has to be devised to remember where each screw came from and return each screw to it's original position and place.
Sep 02, 2008 | GE A730 Digital Camera
LCD Screen has vertical lines and now it is almost white
you will need to send it the sony directly for repairs rather then Precisions Camera in CT since they are only a authorized repair center rather then a direct manc. place.
Please call 1 800 282-2848. Best if you have a proof of purchase to go with it.
Nov 09, 2007 | Sony Cyber-shot DSC-W80 Digital Camera
Damaged lcd screen on Sony Cyber-shot
yes. if you are able to precure the lcd , the changing is not big job.
Oct 30, 2006 | Sony Cyber-Shot DSC-S40 Digital Camera
Casio Exilim EX-S600 Digital Camera Logo
70 people viewed this question
Top Casio Cameras Experts
pontelemon
pontelemon
Ron Grant
Level 1 Expert
Are you a Casio Camera Expert? Answer questions, earn points and help others
