Question about Intel Computers & Internet
Canon i960 paper feed problem
All of a sudden the printer is producing a paper crimp in the middle of beginning edge of paper fed into printer. Rollers have been cleaned several times per manual instruction but does not correct problem. Paper will slant to the right when printer is engaged. Signals paper jam, however paper has hardly entered the printer. Opened printer from the front, seems like one of the bed segments that the paper feeds across is raised( or other segments are lowered do not know which). Cannot correct the problem, afraid to touch the bed segments behind the printing cartridges, ant suggestions?
SOURCE: Canon Pixma ip 2200
send me printer driver canon ip 2200
Posted on Apr 22, 2008
  • 14 Answers
SOURCE: cannot clean Canon i960
The print driver might not be sending the correct color profile for photo paper. Check that your selection of the paper type "sticks", that is, that it doesn't revert to plain paper when you click on the print button.
If the print dialog is not working properly, then please get in touch with Canon's tech support to resolve this.
Posted on Jul 26, 2008
  • 521 Answers
SOURCE: Paper does not feed - GRABS RIGHT SIDE
gears below the paper feeding tray are damaged or some dust particle have blocked the gears try to clean it by blowing the dust use normal greece (oily substance) between the gears so that they can move frequently to pull the paper, and if the gears are damaged you have to change the gears.
Posted on Aug 08, 2008
SOURCE: HP 1020 Issue
Maybe if you hold down the cycle button and let it run through a "test cycle" to receive a printer data sheet it might clear the internal buffer or whatever you call that short term memory these printers have. Let us know. JP
Posted on Mar 17, 2009
aicaxz
  • 511 Answers
SOURCE: epson c90 paper feed problem
Is the message general error? The problem is tchip. When turn on chip is recognized by printer, but when start to print, printer "read" some information from the chip. Here is the error. Some pin at the chip for redaing the existence of chip, other pin for reading the information. Check connector between chip and carriage.
Posted on May 30, 2009
Auto Document Feeder
Make sure the paper is not damp, make sure the paper is not sticking together around the edges. Adjust the paper guides.
Dec 14, 2015 | Canon PIXMA Office Equipment & Supplies
The paper will not feed properly into my mx320 canon printer. It pulls the paper in on the left side but not the right side. I can see no paper stuck anywhere on the rollers. I have removed and replaced...
The mX320 being a rear sheet feeder model can suffer the problem of something falling into the feeder and causing the paper to jam on entry.
To find what has fallen in your will need to gently pull back the fed paper and look at its leading edge. This will show a heavy "Nick" in the edge. observe where the nick is in relation to where the paper is fed and that will indicate where the obstruction is in the feeder. Use a bent paper clip (L shaped) and see if you can feel and dislodge the culprit. Remove the ink cartridges and turn the machine upside down and give it a good shake. hopefull the drawing pin/paper clip/notice board pin will fall out and the world will be at peace once more.
Good luck.
Aug 07, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Paper will not feed through after replacing color
Good day, I suggest you must clean the roller and and use appropriate type of papers. to clean the roller, press power button to turn on the machine then remove any paper from the auto sheet feeder. press menu until maintenance appear the press ok. and try to load load 3 or more a4 letter sized paper and see if the the paper is automatically fed in and then out of the machine.
hope this will help you. have a nice day.
Jul 31, 2010 | Canon PIXMA MP240 All-In-One InkJet...
Canon mp160 paper always feeds skew, can the paper be fed from the bottom instead of the top thanks Peter
Solution obtained on cannon website-paper can only be fed from top(back).This is a common question as the paper tends to feed skew.
Feb 08, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Printer is not feeding the paper through but acts as though it is printing
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-7
Apr 20, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Black marks along the edge of paper
there is probably ink on the rollers. get some paper and just keep feeding it till the black marks stop. and RECYCLE the paper that you fed. DO NOT throw it out
Apr 13, 2009 | Canon MultiPASS F60 All-In-One InkJet...
Cannot clean Canon i960
Jul 26, 2008 | Canon I960 InkJet Photo Printer
PAPER FEED
Assuming that you know where the paper gets feed in, I usually use this trick to start a new roll of paper.
First, tear off the end of the new roll so that there isn't any glue stuck on the paper.
Then, fold the tip of the paper like an arrow. (Fold one side to the middle and the other side to the middle so both sides meet in the middle.
Then, place the paper into the slot where the paper feeds in.. (Usually goes under the printer assembly) and then hit the PAPER FEED button at the same time. If the paper is in the correct slot, the paper should start feeding the paper all the way through.
Hope this helps.
Have a good day.
M =)
Jan 16, 2008 | Canon P1-DHV Calculator
Paper feed
Something is stuck in between the
tray and rollers possibly torn paper
in one of the corners
try with just a few sheets of paper
Once you remove the jam
wilthout breaking any plastic
parts it will work okay
Nov 16, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
I960 canon printer
Lift lid ,let carriage stop in middle, un-plug the printer > Remove all ink tanks > Remove print head > Soak print head in > 3 parts very warm water an 1 part ammonia over night. Rinse under faucet with water directly over ink ports, shake out excess water,(if when you shake it out and if color still comes out repeat soaking for another hour or two and rinsing again ,HAD TO DO MINE TWICE) let air dry. (hair drier helps) Cured my problem for a while ,but if not used almost every day, this will happen again, I also use compatible ink tanks. Don'T believe the inks are as good as Canon Ink. But who the hell can afford them. So fill your owe with Canon ink from Canon. Still seems that the cyan always dries up first. Good luck Lestero1
Oct 18, 2007 | Cannon Canon i960 Photo Printer
Computers & Internet Logo
108 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
