Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
Posted on Oct 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The water lines from the filter housing leak at the solenoid and are dripping at the filter. It is a Whirlpool gold series side by side
Anonymous
Level 3:
President:
  • Master 1,304 Answers
  • Posted on Oct 24, 2009
Anonymous
Master
Level 3:
President:
Answers
1304
Questions
0
Helped
367545
Points
3700
You should be able to push in the ring around the tube at the same time pull the tube out
cut about 1/4 in off and push it back into the hose clip
unless your line is craked this should work for most drip leaks
My "Whirlpool Gold" Refrigerator's interior water dispenser was dripping pretty badly. I just replaced the inlet valve and the drip is MUCH slower but it's still there (1 drip every ~10 minutes). Wha
Perhaps some air bubbles were trapped in the water line during the repair. Try running water thru the line for a good amount of time and that may help to relieve the line of any air bubbles.
1helpful
Water leaking from hose on water filter housing
shut water off to ref and try cutting the end of the tube off, but only 1/8 to 1/4 of an inch.. insert back into housing firmly and turn water back on and see if leak stopped.... if still leaking order and replace the filter housing..... hope this helps....... ken
How to remove hoses on water filter housing
this is hard to explain but here goes..... push the water line in and at the same time push the flange in as well... this will realese the water line, holding inwards pressure on the flange pull the water line out of filter housing... I know this sounds confusing, but when you look at housing it will make more cense.... hope this helps........ ken
Water leaking from water filter housing
if water is leaking from where water line is try cutting the very end off water line and reinstall water line... if it is leaking any where else replace housing
Mod.g17fvcxw001 leaks water from vents inside between light and water filter.
Hi,You will need to look at either the filter or water line too and from the filter housing for the leak. I have seen filters with flat spots on the "O" rings that will cause them to leak, even brand new out of the box.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
My amana side by side fridge water dispenser drips and seems to drip a lot more when say the toilet flushes or the washing machine is running almost like it starts a siphon
Sounds like you need to replace the water solenoid valve, located where the water line connects to the back of the fridge, usually behind the fiber cover at the bottom.
These valves are damaged by dirt in the lines. Dirt and scale roughs up the valve needle and seat, and leak more with lower water pressure.
You can get valvesand valve kits from appliance part stores, Home depot or sears parts via ordering. I highly suggest an external in-line filter that will stop this forever, and suppliment the internal filter for taste. If particles are damaging this valve, it is also slowly causing damage to the other water valves in the bathrooms and toilets. If you have to replace valve washers a lot, then a whole house filter would be worth it.
1helpful
2answers
Water Dispensor leak on Whirlpool Refridgerator
The solenoid valve needs replacing, located at the back of the refrigerator. If you have well water you will need to install a filter on the supply line.
1helpful
Water dispenser is leaking!
The water is controlled by a solenoid valve. If it is leaking, the valve will need to be replaced.
2helpful
2answers
Water leaking from water dispenser
replace your water valves one for the door disp is leaking
2answers
Water dispenser dripping
Your house valve may not be totally closed (bad seal or something) letting a small bit of water through. Disconnect the line to the fridge completely (in the back) to be sure. That way even if the fridge solenoid valve is bad AND the house valve is bad you won't get dripping. If you know the valve is good, there are times when the water filter will have air trapped in it letting the water in the line drip out slowly until it's finally empty. Pull any filters you have also.
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
