Question about Vacuums
Motor replacement for Rainbow D4se
How do you replace motor on the rainbow d4se?
    President:
  • 1,673 Answers
From the bottom, remove the screws separating the top and the bottom. Then at the bottom, remove the round water seal, take out those screws, ( careful with the water seal, reglue it with contact cement when you put it back on). At the top of the motor, take out the scres around the motor and it should pull out.
Posted on Jan 15, 2008
How do I replace the fuse on a rainbow vaccum?
The D4 model Rainbow has a Thermal Cut Off
This has to be manually replaced. It is attached to the Field 120v D4
If this has blown, then most likely something is causing. The Armature Tall 120v D4 could be going bad.
You can also speak with our technical support team Contact Us
RainVac
Jan 27, 2016 | Rainbow D4se Classic Canister Vacuum...
Rainbow E-series will not turn on
Hi, there is no reset button on a Rainbow vacuum. There is a safety switch on all E series and E2 series Rainbow vacuums, that keep it from running without the water basin on it.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also. Thank you, Ralph
One other thing. All E series vacuums have a built in circuit breaker on the motor. Some of the earlier ones, it was only a fuse, and if it blew, it had to be replaced, or removed and wired directly without it on there. Most of them have a automatic reseting curcuit breaker, that will blow and auto reset its self, after it cools off. They do sometimes stay blown also, and do not reset. If that is the case, it has to also be replaced, or removed, and wired directly, with out it on there.
Motor brushes are usually the source of a non working E-2 vacuums and when they burn out, they usually take the motor armature with them, from excessive heat and flare electrical arking to the armature.
Thank you again,
Ralph
Apr 05, 2010 | Rainbow E series Canister Wet/Dry Vacuum
How to change the power switch on a D4SE Rainbow Vacum
Hi there SmartAlec From NelsonVacuums.com.au here. Ok the switch is a tricky one if you havent done it before but the trick is having the right tool. I assume you have got the machine stripped to that point (phillips head screwdriver is all thats required here). You need a tool like a knitting needle but thinner, i am sorry i dont know what its called but basically you put that beside each wire and as you push it in you can pull out the switch wire one at a time. Mark down the position of the wires before pulling them out you can blow a new switch by hooking the wires in the wrong configuration. Hope this helps!. Happy Vacuuming:)
Aug 02, 2009 | Vacuums
Power head Motor
type rainbow vacuum parts in your search browser and there should be tons of sites where you can get the parts .if you want to call all-type vacuum and janitorial supply its 314-275-8006.ask for lisa she can probably get it for you.
Apr 30, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow vacuum model SE
wow, that motor is one of the most complex in a vacuum and to repair it can be very difficult, if you want to replace it you can but it will be very expensive just for the part. the screws are hidden under that big rubber gasket on the bottom of the machine where the water tank sits. you should also replace that gasket two because it will get ruined when you tear it off.
Sep 22, 2008 | Rainbow 75th Anniversary Canister Vacuum
I don't know how to take apart me Rainbow e2 series vac.
I recently took mine apart because the motor stopped working. Realized the brushes were pretty well worn down and one side was completely gone. I was looking on the internet for detailed instructions on how to take it apart. I ended up just ripping it apart with no problems but made a tutorial to help you guys out. Here's a link to it
http://www.vacuumcleanerforum.com/f20/21715-how-take-your-rainbow-vaccum-apart.html
This is for the e-series vaccum, not the e2 but they pretty much have the same design and same motor (e2 has a 2 stage motor).
Let me know if you have any questions
Jul 10, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow d4se assembly
Generic problem for all Vacuums
How to assemble correct movable fan gen., middle fan spacer, rexair d4 lower stage fan and so on? Which side goes first?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You can change the fans on the RexAir / Rainbow vacuum but sometimes that is only a temporary fix, the fans would be new but the rest of the motor may burn out sooner with the added load to the motor and sometimes it is more cost efficient to replace the motor than to repair it and have it break down or burn up the motor, as far as the spacing
You can refer to the nearest vacuum cleaner dealer in your area or in the yellow pages or call the RexAir/Rainbow factory for a schematic of the breakdown of the motor, and you can also cal the factory or check the website and download the owners manual from the website.
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Don – The Vac Man
Apr 22, 2008 | Vacuums
Vacuums Logo
136 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
