Frigidaire Freezer 16.7 Upright Freezer, FFU1764D
Problem for Frigidaire Freezer 16.7 Upright Freezer, FFU1764D
I have 16.7 upright Frigidaire Ultrafreeze
By aldurbin on Oct 24, 2009
I have 16.7 upright Frigidaire Ultrafreeze freezer, Model AFFU1766DW3 & SERIAL #WB51720061, manufactured 04/05 that I purchased new 11/05. Water was on the floor next the the freezer but the light on the inside of the freezer and the exterior yellow power light under the door remained on. I am pretty sure the freezer door was tightly shut when I opened the door. The food seemed still frozen- I shut the door quickly. Frozen water was also on the inside bottom of the freezer. I did not hear any freezer running sound initially. I flipped all my circuit breakers-- though none appeared to be in the off position. Freezer running sound eventually started. What caused the water to be on the floor outside the freezer & on the inside of the bottom of the freezer?? What should I do to prevent this from happening again? Thanks, Anne from Seattle
Best Solution
posted on Oct 24, 2009
Very Helpful)
woodchuck789
Rank: Guru  Frigidaire Refrigerators  Expert
Rating: 91%, 576 votes
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" This advice seems really clear-- and I will get help from my hubby to implement it. Thanks a lot for your help! Anne " - aldurbin
Popular Solutions for Frigidaire Freezer 16.7
Questions and Unsolved Problems for Frigidaire Freezer 16.7
Do you recommend Frigidaire Freezer 16.7 Upright Freezer, FFU1764D?
Answer
Answer
My frost-free upright freezer builds up ice in the bottom of the freezer.
Answer
I have LG fast flow fridgefreezer - it freezes well but everything once its been frozen seems to... (More)
Answer
lights on but no cooling
Answer
top freezer shelf warm and not freezing food --two other shelves below are freezing and working... (More)
Answer
my daewoo american fidge feezer is lighting up, says its working but not cooling. The unit has been... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Frigidaire Freezer 16.7...:
Top Freezer Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Freezer Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
