Question about ASUS P4PE-X Motherboard
P4PE Motherboard system hangs on 2 memory banks
I have a p4pe mobo with 1007 bios version and a 3,2ghz pentium processor.
I'm using 2 kingston dual channel memory stripes of 1024mb each.
When both stripes placed, sometimes the bios says that there is a error found by the hardware monitor. When pressing F1 the system starts normally. But after a couple of minutes the system hangs, not always but 60% of the time it does.
When i'm using only 1 stripe, the one ore the other i don't have any problems. I've tested both stripes of memory and no problems were found.
I'm hope someone can help me on this one.
Best regards, Norbert - the Netherlands
  • nobbie69 Dec 31, 2007
    Thank's for youre support, but it didn't solve my problem.
Yes you can only use 1 stick if over clocking to the 800 fsb if you stay at 533 you can use both. Its referenced on the asus site cpu support. :-)
Posted on Jun 10, 2008
According the asus -site with youre setup, you can only use one bank of memory with youre mobo
Posted on Apr 12, 2008
  • 2,427 Answers
You need to check in your bios settings for the amt of physical memory setting. alsoexamin the board for defect. if all that is good then follow the following instructions
1.)Unplug computer
2.)remove memory
3.)switch jp1 to clear ( the jumpewr that clears the bios is called jp1 its located close to the battery and it has 3 pins and 1 jmper) the pin set will be on 1 and 2 , simply set it to 2 and 3)
4.) Hit the power button 5 times to clear all remains of eletricity
6.) replace memory
7.) boot up system
8.) on the main boot screel it should say no bios settings enter setup
9.) enter setup and load optimal defaults
10.) save and exit
Posted on Dec 31, 2007
How can i boot or reformat using usb in motherboard p4pe-x, or can i boot from usb from that mobo instead? If so, how? I see on boot setup the removable devices, under that after i click removable...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
Apr 27, 2011 | ASUS P4PE-X (90-M8LAW1-G0EAY) Motherboard
Im trying to stall 4 module by kingston khx6400d2ll/1g but the computer only pickup 2-248 g
Follow all the instruction bellow.When you install the ram follow the bus speed because memory speed can not excite the limit from 800mhz.
Elitegroup Computer Systems is known for their array of products from desktop computers to graphics cards and motherboards. At hand today we have their NF650iSLIT-A motherboard, which is powered by NVIDIA's nForce 650i Chipset and caters toward the computer enthusiast crowd, but can it really deliver?
· LGA-775 Socket for Intel Core 2 Extreme, Core 2 Quad, Core 2 Duo, Pentium 4, Pentium D processors
· FSB 1333 (OC), 800, 667, 533MHz
· Supports Hyper-Threading Technology
· NVIDIA nForce 650i SLI
· Dual-channel DDR2 memory
· 4 x 240-pin DDR2 DIMM
· Supports DDR2-800/667/533MHz
· Realtek ALC883
· Marvell 88E1116 Gigabit
System BIOS
· Award BIOS with 4Mb Flash ROM
Hope it will help you.
Jan 07, 2011 | EliteGroup NF650iSLIT-A (V1.0) Motherboard
I want manual and bios of Asus motherboard model
Here's the link to the driver and bios updates. Hope it helps you.
Mar 29, 2009 | ASUS P4PE-BP Motherboard
2.4GHz 533MHz FSB to 2.4Ghz 800MHz FSB
Yes, you can put any Pentium 4 or Celeronsocket 478 processor in there, including those with an 800MHz FSB onthe processor. Don't waste your time with only a faster FSB unless youjust happen to have one laying around, the performance won't improvethat much. This one is $50 from Newegg.
Upgrading the components is not overclocking. Overclocking is when youforce the components to run faster than they are rated for. Yourmotherboard is set up to allow this, through the BIOS. Severaloverclocking features areintegrated into the BIOS, including the ability to adjust the FSBfrequency, and the Vcore, DDR, and AGP voltages.
If you choose to overclock, be prepared to make frequent changes toachieve best performance vs. stability. I would suggest upgrading yourcooling to the best you can afford as well. Your PC may lock up orrefuse to boot for no apparent reason if you overclock. Be preparedfor that and know what to do about it before you start youroverclocking career.
Mar 17, 2009 | ASUS Computers & Internet
I bought a 1GB samsung PC2700 DDR memory for P4PE motherboard. After installed it, the PC could not started. Is that memroy compatible for P4PE?
This page lists the type of ram that is compatible with your system, pay close attention to the voltage.
Take the part number from the stick you're trying to install and punch it into Google to see what the exact specs are.You may find that the voltage is different...
Note: I am not affiliated with the linked vendor it's for illustrative purposes only.
Mar 06, 2009 | ASUS P4PE Motherboard
Bios for Motrherboard P4PE-X
Hi Reinaldo,
I assume your mobo is an ASUS, based on 845PE intel chipset, just follow the link below:
It requires for you to select your OS to download.
Good luck and have a nice day.
Oct 13, 2008 | Computers & Internet
Asus Mobo Will Not Boot After Memory Upgrade
not right ram gotta use samusng low density sum mobo so picky
Jan 20, 2008 | ASUS P4PE-X Motherboard
2 gigs of ram
Re-check your manual at pg. 1-12. 1.9.1 Memory Configurations.
Since you know one bank of memory works fine in a certain slot. Now try the other in the same slot.
Jan 15, 2008 | ASUS P4PE-X Motherboard
PC Problem after installing Kingston PC3200 1G in my Asus P4PE-X
As you can see in the manual page 1-13 to use a memory PC3200 you must have a processor working at 800 MHz FSB, now you probably have a processor running at 533 MHz FSB.
Oct 13, 2007 | 3M (EP7630AVR) Video Capture
Really disappointed with dual core
You can buy a 3.02 pentium 4 processor and need not change any thing else. On the other hand try changing your hard disk with a one with smaller capacity such as 80 GB make it primary with the windows partition not exceeding 15 GB . Make this drive (80 GB )primary and other one secondary.Increase the virtual memory size of your system and for sure you wont need to buy any thing or be depressed anymore.
Oct 09, 2007 | Computers & Internet
ASUS P4PE-X Motherboard Logo
151 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
