Verify proper line voltage to the unit and compressor prior to any further testing, and correct if found below normal. I would check the amp draw thru the compressor circuit. the compressor may very well be "locked rotor" and be pulling a high amp draw. that magic number for locked rotor amps should be listed on the compressor nomenclature plate as "lra". the compressor may not be pulling any amps if the windings are burnt though, as their will not be any flow of power through the device. best of luck, ttfn
Comments:
Oct 25, 2009
- that would depend upon the age of the unit figuring depreciation on that with a compressor probably going to cost you around $300-500 installed and a totally new condenser unit with a full warranty for around the same price, plus installation.. I'd replace the entire unit if over 5 or 6 years old, you'll gain a little to a lot in energy efficiency also depending on how much you want to spend on the new condenser unit.. hope this helps, best of luck, ttfn
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
so if winding is burnt i need a new compressor? You recomend changeing compressor or swaping the whole outside unit
" - lolobond2012
inside unit runs for several minutes then cuts out resulting in red,yellow and green lights...
(More)
inside unit runs for several minutes then cuts out resulting in red,yellow and green lights flashing. The outside unit takes long to come on.
i have a old ruud package unit that needs to be changed out do you have a replacement unit that is...
(More)
I HAVE A OLD RUUD PACKAGE UNIT THAT NEEDS TO BE CHANGED OUT DO YOU HAVE A REPLACEMENT UNIT THAT IS COMPAREABLE TO THE OLD ONE TO MAKE IT A QUICK SWAP? MODEL#URGG-10E60JKR
