Question about Sony Ericsson Walkman W810i Cellular Phone
Water damage my w810i dropped in w.c i opened it and dry it and clean it with 95% alcohol . my phon is working but it's speed is very low rather than before what can i do?
    Problem Solver:
  • 6 Answers
Erm not a lot probley re flash your phone im 80% shure that this will speed your phone up
Posted on Dec 31, 2007
Keypad malfunction
Possible causes :
1, The most common problem is foreign debris interferring with the momentary contact switches on the keyboard. (95% of the time)
2. The next most common problem is the keys are just worn out but this would be rare since other keys would likely be affected
3. Keyboard membrane underneath is damaged and interfering with reliable contact
Two approaches:
A. First, you can try a can of air to blow the debris out and then vacuum the keyboard and all grill openings in the laptop.
B. Second, buy a bottle of 99% Isopropyl Alcohol and with the power adapter detached and the battery removed you can flood the area with alcohol to clean underneath and let it dry overnight. I use alcohol as it cuts the greasy junk whereas water will not and water takes a lot longer to dry out. (Hair dryers will speed it up)
If this is not helpful then the laptop case needs to be opened and the keyboard assembly inspected for damaged switches.
This assumes you have checked the software driver for the keyboard and it is functioning normal otherwise.
Nov 14, 2013 | Lenovo ThinkPad Computers & Internet
Tip
What To Do if I Drop My Cell Phone in Water?
The small convenient size of cell phones unfortunately also makes these electronics accident-prone, especially when it comes to water. If you drop your cell phone in water it is often possible to salvage it. If you drop your cell phone in water, you may have only seconds to retrieve it, so you need to act fast even if it means retrieving it from the toilet!
The next thing to do if you drop your cell phone in water is to remove the battery immediately without even hesitating to turn off the power. Dry the batter with a towel and set aside to dry thoroughly. The battery itself may or may not work again, fortunately batteries can be replaced fairly inexpensively. Even if the battery does work, it is a good idea to get a new one.
After you have removed the battery, dry off the cell phone with an absorbent towel as best as you can. Use cotton swabs to soak up water in crevices and on any fragile, exposed circuits. It is also helpful to disassemble it if you can and let all the parts dry separately. Just be sure that you know how to put it back together. If it is a flip or sliding cell phone, leave it open.
If you drop your cell phone in a beverage or in salt water, rinse the phone off with fresh water once you have removed the battery. Once you drop the phone in water, the additional rinsing will not do further damage, however, minerals or other materials will.
If you drop your cell phone in liquid that isn’t pure water, you may want to try giving it an alcohol bath. The alcohol will displace minerals and microscopic substances as well as aiding in the evaporation of the fluid. If it is available, you should use an alcohol concentration of 95% rather than rubbing alcohol that usually contains only 70%.
Once your phone is clean, leave it in a warm dry area or near an air conditioner for three days before you attempt to replace the battery and turn it on. This is very important, because although you may think that you have thoroughly dried it, the slightest moisture can react with the battery and cause it to short circuit. If droped your cell phone in water, and want to save it, resist the temptation of turning it on to see if it is working until you have waited at least 72 hours.
on Mar 10, 2010 | Cell Phones
SonyEricsson T707 was dropped into water. On recovery (2mins ) later stripped outer covers off and removed battery and sim card. Used hairdryer on unit for about 20mins. Can you suggest anything else I can...
The next thing to do if you drop your cell phone in water is to remove the battery immediately without even hesitating to turn off the power. This reduces the risk of a short circuit which would render your phone useless. Dry the batter with a towel and set aside to dry thoroughly. The battery itself may or may not work again, but fortunately batteries can be replaced fairly inexpensively. Even if the battery does work, it is a good idea to get a new one so as not to risk it leaking battery acid in the future.
After you have removed the battery, dry off the cell phone with an absorbent towel as best as you can. Use cotton swabs to soak up water in crevices and on any fragile, exposed circuits. If you have dropped your cell phone in water, it is also helpful to disassemble it if you can and let all the parts dry separately. Just be sure that you know how to put it back together. If it is a flip or sliding cell phone, leave it open for maximum evaporation.
If you drop your cell phone in water that isn’t pure such as a beverage or in salt water, rinse the phone off with fresh water once you have removed the battery. Once you drop the phone in water, the additional rinsing will not do further damage, however, minerals or other materials will.
Once your phone is clean, leave it in a warm dry area or near an air conditioner for three days before you attempt to replace the battery and turn it on. This is very important, because although you may think that you have thoroughly dried it, the slightest moisture can react with the battery and cause it to short circuit. If drop your cell phone in water, and want to save it, resist the temptation of turning it on to see if it is working until you have waited at least 72 hours. Unless you have insurance for your cell phone which covers water damage, there is no point in sending it to the manufacture with the hope that they will replace it under warranty. If you drop your cell phone in water, the technicians will be able to tell immediately due to moisture sensitive stickers that are contained inside almost all cell phones. The best thing to do is to try the tips mentioned above and repair it yourself.
Jan 03, 2010 | Sony Ericsson T707 Cell Phone
I droped my voyager in water
HI,
PLEASE USE HAIR DRYER TO DRY IT AND DONT CHARGE OR SWITCH IT ON FOR A DAY....................................
thank you for using fixya,rate my answer,
vijay
Oct 04, 2009 | LG VOYAGER VX10000 Cellular Phone
Dropped phone in a bowl of liquid
REMOVE THE BATTERY!
*Choice one- Methyl Alcohol
Clean the circuit with Methyl Alcohol
  • Dip a q-tip in the alcohol and squeeze the q-tip.(you want it to be almost dry)
  • Very carefully clean the circuit and allow it to dry, it is important that you clean around the medal to prevent short circuits.
*Choice two- Rubbing Alcohol
Clean the circuit with Rubbing Alcohol
  • Rubbing alcohol has a slower evaporation rate so you need to wipe the area with a clean q-tip after cleaning it with the alcohol.
If this dose not work you need a new phone, good luck.
Aug 15, 2009 | Motorola Mobility RAZR V3
Won't recharge, won't reset
soak unit it rubbing alcohol if dropped in water(water has deposits when dry that short stuuf out alcohol cleans and leaves no residue)let soak for a few hours(make sure battery is out)then shake out excess alcohol and let dry for a day in warm dry area.clean contacts on battery with alcohol ans qtips and reinstall battery then try to charge-same thing happened to me tried this and worked fine hopefully didnt short chips!!!!!Best of Luck to you!!!use 90% rubbing alcohol!!!let me know if worked!!!
Jun 30, 2009 | Sony Walkman NW-A808 MP3 Player
W810i water problem
hi
pls dont turn on the mobil when it is droped in water. it may lead to the internal ciruit damag as the power flow from the battery ill easily pass through the liqued on the internal circuit..
pls remove the battery from the handset and sim also. if u have the hair drier pls blow it on the 10 cm distance with normal speed . so thst water ill vaporise and u can use the mobil again
Note: 1.air blow should be done on the circuit at low speed and 10 cm distance . ok
Feb 08, 2008 | Sony Ericsson Walkman W810i Cellular Phone
I dropped my W810i and now, my screen is all white... all the fuctions work though..
My Frnd..
if you have the know ledge of phone then only u can open the phone and check the strip which came from PCB ( Printed Circuit Board ) to LCD or just take a tissue paper and clean it ... that all other wise u have to change the strip..
Nov 18, 2007 | Sony Ericsson Walkman W810i Cellular Phone
White screen sony ericsson w810i
i got the say problem 2 days back. I read some pots in forums. This is what worked for me. First fully charge the phone some. Get a friend's phone or something. Then get ready with the data cable and your computer with internet.
Goto Sony ericsson site.
search for w810i SEUS Sonys update system.
At the bottom result it says"Sony Ericsson - Support - Update Service Compatible with K510i W810i W200i .
Click on that and dowload the program. At the right corner it shows the phones which supports it.
install the program and run it.
do exactly what it says.
it worked for me. I got all my contacts and messages back.
Good luck
-Manoj
Nov 03, 2007 | Sony Ericsson Walkman W810i Cellular Phone
Sony Ericsson Walkman W810i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
