Question about Grindmaster 875 bulk coffee grinder
Gm 875 parts
I'm having trouble getting a switch for a grindmaster 825. It's a 3 position switch, " start- stop- center". Any idea's.
  • 25 Answers
Any three-pole momentary switch with the correct rating would work. Try Radioshack or the like.
Good luck.
Posted on Jan 08, 2008
How do i adjust the blades/grinder on my Grindmaster Automatic Gourmet/Grocery Coffee Grinder Model 876
I don't see a model 876, but there is an 875s. Here is the wesite for frindmaster and the 800 number or user manual for help. Coffee Grinders
May 15, 2014 | CoffeeForLess.com Grindmaster Automatic...
I have a Grindmaster model 805 coffee grinder. It worked flawlessly for many years, then suddenly stopped. I took it in to a repair facility and was told the switch had died. I had another machine at...
Most grinders, especially the larger professional models will eventually need to have the grinding wheels (set of 2) changed out. They do wear down. The grinder will struggle as the burrs on the wheel dull out. This increases the time it takes to grind coffee and puts a heavy electrical load. Burnt out switches, tripping breaker, overheating, and burnt coffee grounds on espresso size are all symptoms of a worn burr set.
It's common to find; stones, nails, jewelry, and small loose things found around coffee counters in the grinding wheels or burrs. Have a qualified operator remove all beans and hopper to check and brush out burr set. This should be done every day. Talk to your vendor if you find nails as they can easily correct this with a magnetic pick up.
Another cause is very oily beans. Sometimes poorly roasted beans come out extremely oily which will gum up everything from the burrs, Moving parts, and electrical components. Disassembly of entire machines may be necessary.
.Final note; since you mentioned a switch swap. It's possible the switch is underrated for use in this machine. Most will work in a pinch but like a 'spare' tire in a car, they are only ment to get you to a service center for replacement.
Nov 08, 2017 | Grindmaster Coffee Makers & Espresso...
Coffee grinder wont start
Its been a while since i worked on a grind master so have a little patience with me. First, if the breaker went then there might be something blocking the burr chamber like a rock or screw or other obstruction. Second I would check the micro switch for the bag holder if there is one on your model using an ohms meter.
Mar 16, 2012 | Grindmaster 875 Electric Burr Grinder
What is the correct idle speed for my escort 1.8 16v r reg escort
Idle speed for your car/engine should be 875 +-50 that means between 825 and 925 rpm.
Feb 25, 2011 | 1998 Ford Escort
Whatever the setting is at the grind is always fine. What can I do to re-calibrate the grinder?
Grind Adjustment Tools required: Large blade and medium Phillips head screwdrivers In order to adjust the grind, follow these steps (Refer to figure A): 1. Remove all coffee from the hopper. 2. Set selector knob to the finest setting (Espresso or Turkish) depending on the model. 3. Loosen both knob retainer screws in selector knob one turn only. 4. While pressing the bag switch, located behind the spout, press the START button so that the grinder will run during adjustment. 810 model - Press the ON or START button so that the grinder will run during adjustment. 5. With the grinder still running, turn the adjusting screw in the center of the selector knob slowly to the right until a slight clicking noise is heard. Immediately turn the adjusting screw to the left one grind setting. This is the finest grind obtainable. 6. Tighten both of the knob retainer screws. Once the ESPRESSO grind has been set (Turkish for Model 835, 875, 890), the other grind settings will automatically set correctly. 7. Press the STOP or OFF button. IMPORTANT: Always be sure the grinding burrs are not touching while the machine is running on the ESPRESSO/TURKISH setting. Otherwise serious damage to the motor may result. dr_buckhead.png
Nov 19, 2010 | Grindmaster 810 T Electric Burr Grinder
Oldsmobile Delta 88, Idles High on Cold start with DTCs
Sounds like a vacumn leak. Gasket under intake plenum may be leaking. Be sure the pcv valve has the o-ring around it in the correct place also as it will set a code.
Jan 18, 2010 | 1997 Oldsmobile 88
How do i change the burrs on grindmaster 875
Remove the screws on the knob with the grind setting, that pulls out and gives you access to the burrs.
Jul 17, 2009 | Grindmaster 875 Electric Burr Grinder
Candence 825, motor not driving belt, smells of burning
Hi Jill, have you found a solution yet as I seem to be getting a sililar error. Do you get a E02 message and a beep. Thanks Nicky
May 18, 2009 | Cadence Weslo 825 Treadmill Walking Belt
Coffee Makers & Espresso Machines Logo
165 people viewed this question
Top Grindmaster Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Kolbrun...
Ross Keen
Are you a Grindmaster Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
