Question about Samsung LE40R74BDX 40 in. LCD Television
DTV locked on ITV1
Cannot access Digital channels as DTV stuck on ITV1 and no way of accessing channels setup on menu
Thanks
Vincent
  • Uptons Mar 03, 2008
    LE37R74DB Stuck on Radio 2, unable to access DMenu. Will not change channel. Is there a full reset function back to factory defaults so I can start again?
Do a reset in the service menu the turn the tv off and press..
info>menu>mute>power on
and go to the reset option. don't mess with any other setting in this engineer menu.
Posted on Apr 16, 2008
I am trying to program the RCA ColorTrak Plus TV to my satellite receiver and I get nothing but snow
You will need to get a "regular" Universal remote and program it for that particular model of TV. You will need to access the on screen setup menu for the TV and then have it scan the channels. Make sure your DTV box is on and connected with the coaxial cable. If the "TV Input" button on your DTV remote works and you can get it onto the Video Channel, You can connect your DTV receiver with the RCA Cables (Red, White and Yellow) and get your picture that way. If you access the on screen menu, you will need to scan for Analog and Digital channels as the receiver transmits in Analog. hope this helps.
Sep 24, 2012 | Televison & Video
I cannot retune my samsung tv- model no LE37C53CF1W- COULD YOU ADVISE HOW TO RETUNE, mANY THANKS, Jim Lauder
Hi,Does the icon look like a large satellite dish?
Make sure your TV is on "TV" and not "DTV" before retuning.
To re-tune analogue channels:
I have a Samsung TV and that icon is not accessible from the menu if i am watching the tv on the digital option of my remote. You have to switch your tv to the "tv" option on your remote and you will be able to access the icon from your menu.
(on your remote, you should have a button with TV/DTV on it)
To re-tune analogue channels, if you want to re-tune digital channels, then look for the "D MENU" button on your remote. Press this then scroll down to the icon that looks like a large satellite and then on "Auto Store" This will re-tune your digital channels :0)
Take care and hope it helped.
May 28, 2011 | Televison & Video
My mintek dtv-373-d is stuck on encrypted channela nd will not do anything else. I can't get the menu to come up or anything to change. help
I'm assuming you have Cablevision. This is becoming a known problem with their broadcasting system. They have been upgrading and it has been causing the TVs to freeze up on a specific channel .
Simple way to fix it:
1. Unplug tv
2. Unplug coax from tv
3. Plug tv back in
4. In the Menu go to Setup > CH setup > CH Memory > Cable (digital)
5. Enable channel skip for channel that it is currently stuck on
6. Push Menu to exit
7. Change to any other channel
8. Reconnect coax to tv.
Followup:
Avoid this channel and go give Cablevision a call and let them know about it. They won't do anything to fix it until they get a certain number of reported issues about the problem
Dec 08, 2010 | Mintek DTV-373-D 37 in. LCD HDTV
Problem, unable to access any digital channels. TV displays error message Database Empty, any way of removing this message and accessing DTV again. Thanks
If the database is empty you need to re load the system.
With your remote controller, go to menu and from that you need to select install or setup.
This will scan for all available channels and store them for use.
Hope that helps.
Nov 19, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Cannot access 'channel'' menu in samsung DTV menu to carry out retune. The menu jumps from 'sound' to 'setup', the 'channel' icon is greyed out and cannot be accessed.
This is becouse you had done some Channel Child Lock first open all child lock than try to tune channel.Or possible that you are in some other input mode.select TV mode than you can try.
Jan 22, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
Icannot access dmenu on the remote. samsung le26r7
my samsung le32 tv is stuck on BBC 1 Mono. i cannot access the D menu or change on to any DTV channels. I am in an area that broadcasts in digital. the tv works ok if I connect a freeview box
Oct 01, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Samsung LE40R73BD DTV freezing, wont chnage channel
i've just some digging around and found that you can access a service menu and perform a reset which sorted the issue for me.
Access the service menu by pressing, in order, whilst the tv is in stand-by mode:
info
menu
mute
power
when the tv comes back on you will have a service menu; select option 12 (reset) the tv will then switch off.
this will reset your TV back to factory defaults.
turn tv back on and you should be prompted to go through the plug and play setup again - go through everything and then all should start working OK (it did for me)
HTH
Oct 24, 2007 | Televison & Video
Digital Tv is stuck on a channel
I have found the solution at last :)
Put the TV in standby and press these buttons in order
Info, Menu, Mute and Power on.
You will then see a hidden menu, on line 12 select reset
Bingo :)
Oct 23, 2007 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Samsung LE40R74BDX 40 in. LCD Television Logo
562 people viewed this question
Jerry Greenberg
Jerry Greenberg
