Question about IBM T560 (Black) 15" LCD Monitor
0 characters
1 Points
Singer 21 in chess power supply k2629 sSTR chopper
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Oct 15, 2014 | Computer Monitors
Howtorecognise antique ivory
Probably the best way to confirm what the set is made of is to go to a reputable antiques store and have them take a look at the set.
Apr 30, 2014 | Computer Monitors
The clock on my computer is always running slow and I have to regularily alter it.
The only way I can think of to 'fix' a pc clock running slow is to set it to automatically sync with an online clock.
You could try a program like NetTime (Link Here) and have it automatically sync it so it's the correct time.
Apr 17, 2013 | Acer AL Computer Monitors
How can i fix date and time stamp on sony cybershot DSC W610 camera so that when i print photo it automatically shows date and time in the image
The DSC-W610 will not deface your photos by scrawling a string of numbers across them. However the date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Apr 04, 2013 | Sony dsc-w610l - Cybershot Dsc-w610l 14.1...
Santai TD-V26 user manual
The device has an on/off toggle switch and four control pushbutton switches (left ro right) are:
1. Menu (FM Radio or MP3 Player) select
2. Play/Hold
3. Back/Previous
4. Forward/Next
Inputs and output are:
1. 1/8" External Source Input Jack
2. Micro SD Slot
3. Mini USB 5v External Power Input
4. 1/8" Headset/Output Jack
5. USB Memory Card/USB Cable Input/ (Right Side)
The Menu switch has two functions, MP3 Player and FM Radio as indicated by the display. If the Play/Hold switch is pushed in and held for a few seconds the radio will automatically sweep and put the available local stations in memory. The back and forward switches are used to select the desired station. The display indicates station channel number and broadcast frequency (MHz).
In the MP3 Player function Menu function the Play/Hold Switch starts and stops the player. Back and Forward switches select the previous or next track. Simple as that. The player automatically plays the next file if left alone unless the Play/Hold switch is pressed. The display indicates file number and play time. No other functions, like folder selection, were found. If a 5v dc supply is connected to the Mini USB connector the battery will remain charged and it can be used as a small table radio/player. No tests were made to see how long it would operate on its internal battery.
The sound is good and better than expected for a device its size. Enough sound output to hear it in any part of an small house (With some distortion of course). The volume is controlled by holding the forward or back switches in for a couple of seconds and it will switch to volume level control. The display is LED rather than LCD and easier to view. It is on continuously when the player is working with the charger attached.
Aug 23, 2012 | Santai TD-V26 Portable Mini Digital...
Why my display show plug and play monitor instead SyncMaster 732nw?
Apr 17, 2010 | Samsung SyncMaster 713BM 17" LCD Monitor
I am a member on Club Pogo. All of a sudden my program will not open. I get to where it says play now and then the game says loading and just never opens.Everything else works just fine and it also plays...
Im going to give you a few solutions to try out.
1.Turn off Ad-blocking
2.Reinstall your browser installation
3.Reinstall your Java installation (if you dont have it install it)
4.Clear your browser cache
If i helped please leave me a rating. If you still need help leave me a comment and ill try again.
Mar 03, 2010 | HP Compaq FS7600e CRT Monitor
Installing monitor problem
The Gateway FPD1530 is plug and play and should be automatically detected by the Operating System. In your display properties it will say plug and play monitor as Monitor type.
Jan 08, 2009 | Gateway FPD1530 15" Flat Panel LCD Monitor
Video dvd fail to play ! I get " error code message c00d1163 "
What you probly need to do is reinstall the codecs windows xp or what ever does'nt come with DVD codec you can try going here
1I have a few question's for u what are runing Xp home or pro
2 are u only watching dvd's
3 do you watch or want watch more than DVD's I.E. DIVX,FLV,XVID,other formats e.t.c....
the only reason I ask of this because there are couple better player then WINDOWS MEDIA PLAYER.
here there are
If you still want to use WMP just got the first site
and go to this other here
Okay hopefully that help
now with you second problem sounds like registy problem's,that may lead to the error messages
i.e there's a other a program looking for dll's(links) can't find that link,so what you hope to do is find the links,
you can use software to do so but using (regedit), it will better if you know what you doing, I dont know what level computing you have so use the software here
free program don't blame me if it doesn't work here
Dec 12, 2008 | HP Computer Monitors
When i start to play a game after 5 mins of playing,it will automatically shutdown the monitor
can u tell me wat games do you play?
and the system requirments of the game and specs of your pc.
Mar 06, 2008 | Smart Modular SV3170A
IBM T560 (Black) 15" LCD Monitor Logo
19 people viewed this question
Top IBM Computer Monitors Experts
Brian Sullivan
Brian Sullivan
William Miller
William Miller
Are you an IBM Computer Monitor Expert? Answer questions, earn points and help others
