Unhook that and go straight from cable outlet to TV do not put cable out into a surge protector this will cause issues with the signal as the signal is now coming in digital and not analog anyhow it used to work yes but the cable company changed and now so do you. A regular TV will work because of its non digital tuner this one has a different tuner that relies on the digital signal Clear qam. If you still got same result call cable company if that does not work you might have a bad tuner and lets just hope that is not the case.'
I worked hard to get you a intelligent answer so if you can press the ACCEPT button that would be wonderful!!
Popular Solutions for Samsung LN-T4061F 40 in. HDTV
samsung lnt4061f there is a slight shadow of what looks to be about 3 inches wide and about a foot...
(More)
SAMSUNG LNT4061F THERE IS A SLIGHT SHADOW OF WHAT LOOKS TO BE ABOUT 3 INCHES WIDE AND ABOUT A FOOT LONG..IT ACTUALLY LOOKS LIKE A SMALL HOAGIE/SUB ROLL..IT IS PRETTY MUCH ALL THE WAY TO THE LEFT OF THE SET AND STARTS ON THE BOTTOM GOING UP..WHERE THE SCREEN MEETS THE BOARDER THE SHADOW IS DARKER..VERY VERY NOTICEABLE WHEN SCREEN IS WHITE OR A LIGHT COLOR..CAN'T SEE IT WHEN BLACK..SAMSUNG SAYS TO UNPLUG POWER CORD AND HOLD POWER BUTTON DOWN 15-30 SECONDS TO RESET THE TV..HAVE HAD TV NOT EVEN TWO YEARS NOW..CONTEMPLATING CONTACTING ATTORNEY GENERAL AND BBB TO FILE A COMPLAINT..I AM HOPING IF THERE IS ENOUGH COMPLAINTS THERE CAN BE A CLASS ACTION LAWSUIT FILED AGAINST THEM..THIS IS ABSURD..
Our samsung LN-T4065F works for awhile then the screen starts blinking. there is no set pattern to...
(More)
Our samsung LN-T4065F works for awhile then the screen starts blinking. there is no set pattern to this...It may stop in a hour or may not stop all day
