posted by hehal on Dec 31, 2007
When I start my Laptop The LED lights up but then it gives the error Unable to locate the OS.
Comment by hehal, posted on Jan 02, 2008
I have tried Re-installing the OS but it still has the same problem...
Best Solution
posted on Dec 31, 2007
Does the hard drive show up in the bios?
It sounds like you operating system is damaged and you will need to reinstall it.
If there is anything you need to get off the hard drive you will need to put the hard drive into a desktop via an adapter or use a bottable disc program called backtrack2 to get data off and onto a memory stick.
Hope this helps?
Hope this helps?
Comment by postmanfw, posted on Jan 02, 2008
Is the boot order set correctly in the bios? Its should be set to cd 1st then hd then removable devices. Sounds like its trying to boot from something other than hd.
Rating Locked! (?) hehal has rated this solution as Helpful
This Problem Also Relates To:
HP HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
HP Compaq Presario V6000T (EZ855AV) PC Notebook
HP Pavilion dv8000t PC Notebook
HP Compaq nx9600 PC Notebook
HP HP Compaq 6720s Notebook PC PC Notebook
HP Compaq Evo Notebook N600c PC Notebook
HP Compaq nc6220 PC Notebook
Can you Help with these PC Laptops problems?
Dell Inspiron E1505 PC Notebook
No Sound/drivers fine/possible...
My laptop sounded like a... Answer This...
HP Pavilion zd7000 (DF867AV) PC Notebook
HP ZD7000 laptop screen won't...
Everything powers on. When i... Answer This...
Repair Service
Find PC Laptop Repairman Near You:
