Mitsubishi WS-55513 55 in. Rear Projection HDTV Television
Problem for Mitsubishi WS-55513 55 in. Rear Projection HDTV Television
Everyone on the screen is Green
By jska15 on Oct 24, 2009
Solution #1
posted on Oct 24, 2009
Not Rated)
nileshsingh2
Rank: Wiz  Televisions & Videos  Expert
Rating: 84%, 68 votes
SEEMS YOUR (G) IS HIGH, MEANS GREEN. IT CAN BE ADJUSTED MANUALLY, TRY TO SETUP FROM REMOTE, IF IT DOES NOT FUNTION, THEN YOU HAVE TO TUNE YOUR RGB OPENING THE TV. ALSO CHECK THE 15KOHMS RESISTOR ON CRT BOARD. RESOLDER THE WHOLE BOARD
Was this helpful?
Yes
No
Popular Solutions for Mitsubishi WS-55513 55 in.
Questions and Unsolved Problems for Mitsubishi WS-55513 55 in.
Do you recommend Mitsubishi WS-55513 55 in. Rear Projection HDTV Television?
Answer
Answer
Light blinks and System reset does not reset, therefore the tv will not turn on. I have unplugged... (More)
Answer
Only showing in black and white - how do I get it to be color?
Answer
want to control pip on ws55311 mitsubishi tv using time warner at8560 remote .cant seem to find the... (More)
Answer
TV is 5 years old [3 weeks out of warranty :-( ] Apparently had a brief power outage, tv is plugged... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Mitsubishi WS-55513 55 in....:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
