Dell ? V305w All-In-One R840635AU InkJet Printer
Problem for Dell ? V305w All-In-One R840635AU InkJet Printer
My dell v305 printer won't print. commumition
By cottonhampop on Oct 24, 2009
my dell v305 printer won't print. commumition problem. I have done everything to try and solve problem. help
Solution #1
posted on Oct 25, 2009
Not Rated)
black_pnix
Rank: Guru  Dell Expert
Rating: 87%, 23 votes
hi there!
-you need to uninstall and reinstall the program of the printer, if you have already done it. you may try the step below but it will still ask you to uninstall the printer software.
You can try these steps:
1.Check if the firewall is blocking any printer services 2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode 3.Disable all the firewalls 4.Uninstall the printer driver and software 5.Delete any items under the ff keys: NOTE: Be Exact on the File Directory ! HKLM = Hkey Local Machine -Click Start then type REGEDIT then press Enter -Delete any items under HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3 Optional*** 6.Delete any non default items under the ff keys: Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED HKLM\System\CurrentControlSet\Control\Print\Monitors HKLM\System\CurrentControlSet001\Control\Print\Monitors Default items are as follows: AppleTalk Printing Devices BJ Language Monitor Local Port PJL Language Monitor Standard TCP/IP Port USB Monitor Windows NT FAx Monitor ***** 7.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Printers HKLM\System\CurrentControlSet001\Control\Print\Printers 8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista) Ensure there are no documents in queue. Disconnect printer’s USB cable. Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility. From the start search box type spool and press . The spool folder located at c:\windows\system32\spool opens. Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup. Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup. 9.Restart the computer. 10.Check th services status Start-Run- Type Services.msc and Click on Open You will see long list of services You need to make sure following 4 Services are set to Automatically start Remote Procedure Call RPC Remote Procedure Call RPC Locater LexBce Server Print Spooler 11.Reinstall the latest printer driver
Was this helpful?
Yes
No
Popular Solutions for Dell ? V305w All-In-One
Questions and Unsolved Problems for Dell ? V305w All-In-One
Do you recommend Dell ? V305w All-In-One R840635AU InkJet Printer?
Answer
Answer
how do i change the size of the words on my coper so the print is larger
Answer
can not get dell imaging tool box to install, it pops up a window that says error 1-2010
Answer
when I press scan to computer it reads downloading application list, then says this can't be done. I... (More)
Answer
i just installed a new ink cartridge on the left side and it keep getting an error message
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printers Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
