Question about Ricoh Aficio 1035 Copier
LENS ERROR I'm recieving an SC322 error when am photocopying. Please assist so as to solve this problem so as to start using the copier.
  • joff Dec 31, 2007
    SC 322 appears as the machine initialize.
  • Anonymous Mar 17, 2009
    sc 322 erreur
  • 417 Answers
SC322 is the laser error you could remove it and check the polygon mirror and the mirrors are all in line. The polygon should move easily not stiff. if this is so you can either remove the polygon by the four gold screws and move the black clip that hold the mirror in place and lift the mirror off. Once you have done this drop one drop of oil (Thin) into the whole where the pin of the mirror goes be careful not to drop too much in. replace mirror and install. (Important you must have all the covers back on as the laser is extremely dangerous.
If everything is OK or that you have performed above turn the machine on and follow these steps.
press the yellow button followed by
1 0 7 on the numeric keys then press and hold the pink button (Stop key) until the screen changes then you are in service mode. Press Copy Service mode and the screen changese once again.
When you in that mode turn the machine off using the switch on the left hand side wait 10 seconds then switch back on then hopefully this should work if it doesn't then the laser unit will need replacing
Thanks hope this works for you and please rate me
Thanks Jason
Posted on Dec 31, 2007
Error code F2-40 in Sharp mx m314n photocopier
using third party toner or drum replace toner and drum with OEM
Jun 04, 2015 | Sharp MX-M314N Copier
SC 322
sc 322 how to solve this error
Jun 16, 2010 | Ricoh Aficio 450 Copier
Please solve this problem Ricoh 7650 Code SC 902, 302 and 322
SC322: Laser Synchronization Error
Definition [B’]
The laser synchronization signal cannot be detected from the synchronization
detector even if the laser diodes are activated.
Possible Causes
• Poor connection between the laser synchronization detector and the LDB
• Laser synchronization detector out of position
• Laser synchronization detector defective
• LDB defective
• SICU defective
• Front door safety switches defective
SC302: Charge corona output error 1
SC902: counter error
Mar 31, 2010 | Ricoh Aficio 1035 Copier
My Photocopier displayed error H4 on the screen
Dear sir
H4 signal is fuser unite problem please call a technician they solve this problem.Just we serve problem location because i am not live your area.
Aug 12, 2009 | Sharp Office Equipment & Supplies
Functional Problem SC322
Polygon mirror motor is bad. Sometimes you can put a drop of oil on the shaft, but at best is a temporary fix. You'll end up having to replace it. Good luck
Jul 13, 2009 | Lanier Office Equipment & Supplies
I need solution to aficio 200 error code sc322
sc322 is a Laser synchronization error:
Means that the laser synchronization signal cannot be detected by the main scan detector board.
Possible causes:
Poor connection of the interface harness which connects the laser synchronization detector board and the BiCU board.
Laser synchronization detector board out of position or is defective.
BiCU board is defective.
Unfortunately,unit needs service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 19, 2009 | Ricoh Aficio 180 Laser Printer
No instructions ... how do I use Lexmark x 1270 as a photocopier
Here is the user guide:
Thanks, Joe
Feb 13, 2009 | Lexmark X1270 All-In-One InkJet Printer
How can I solve error E214 of my canon 6260 photocopier
The error code deals with the scaner / mirrors or lamp. When you turn the copier "ON" will the scanning lamp turn on? If not your Lamp is blown or it could be the thermal fuse for the lamp, but it is most likely the lamp. It could also, mean that the Lens is not moving into home position.
Jan 05, 2009 | Canon imageRUNNER 210S Copier
Ricoh Aficio 1035 Copier Logo
536 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
