Question about Neff W4380X1 Front Load Washer
Power cuts when 'on' switch is released!
Hi. I have a Neff W4380X1 front load washing machine. As of last night we have to 'jam' the power switch in for the machine to operate. As you push the switch, it all lights up and looks fine but as soon as you release it, the power cuts. If held in position the cycle runs as normal. I guess its the switch but not sure how to get to it?
Easy, remove the top the switch unclips and slides out from the front panel, you cannot sucesfully repair these switches so a replacement should be obtained
Posted on Jan 03, 2008
Why is my washing machine very loud and noisy when spinning?
Because you are sitting inside of it and you are an unbalanced load. Get a friend of equal weight to sit on the other side of the agitator and the noise will disappear.
May 13, 2014 | Neff W4380X1 Front Load Washer
Neff washing machine not spinning
sounds like motor brushes have worn out will need to remove motor to replace they are inexpensive.the clicking is the relay telling motor to rotate clockwise or anticlockwise.
May 30, 2009 | Neff W4380X1 Front Load Washer
My nef washing machine fills with water but doesnt spin ive cleaned the filters this has not solved it
Hi there - past experience tells me your water pump is U/S try this before anything else
Apr 28, 2009 | Neff W4380X1 Front Load Washer
Needing to replace the brushes on a Neff W4380X1GB
not the motor but the program switch
the motor only gets instructions from that switch or program board and the motor is running well if it does the rest of the wash well
Dec 02, 2017 | Neff W4380X1 Front Load Washer
Neff W4380X1 LED 01 appearing
This is a water supply fault. Check that the hoses at the back of the machine are not squashed and check to see if there is water getting into the machine
Aug 31, 2008 | Neff W4380X1 Front Load Washer
Neff W4380 error or warning '03'
Hello there,
when the machine makes drowning sounds and beeps error dry (while trying to drin out) blow strongly into the drain pipe. It should result in a higher flow of water out the drain pipe and error 3 should go away.
Jun 02, 2008 | Neff W4380X1 Front Load Washer
Detergent & Conditioner Drawer
Perhaps it needs to be thoroughly cleaned out first - sometimes the gloopy mess collects and blocks the outlet hole.
Oct 30, 2007 | Neff W4380X1 Front Load Washer
Neff w4380x1gb
We have had the same problem - £208 for a new power board - IT DID NOT FIX THE PROBLEM
Jun 01, 2007 | Neff W4380X1 Front Load Washer
Neff W4380X1 Front Load Washer Logo
159 people viewed this question
Top Neff Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Billy Detlefsen
Are you a Neff Washing Machine Expert? Answer questions, earn points and help others
