Question about Sharp AR-5320 Black and White Copier
H2 Error Please give the solution for H2 error in Sharp AR-5320 Printer
  • lenient02 Aug 05, 2008
    if i power-on the Copier, it will be displaying H4 on the screen and other buttons will not work. it will be showing H4 only without booting. please what can i press to make the copier work again.
  • sunnywoochit Mar 13, 2009
    H 2 flashing
    Sniper:
  • 54 Answers
You have a thermistor open. That means that the device that reads the temperature in the fusing unit, has broken. You will need to replace the fusing unit to fix this problem. You could try a Sim 14 reset. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
Posted on Jan 01, 2008
  • 57 Answers
You need to replace your fuser unit. this will solve the problem.
thanks
Posted on Jan 12, 2008
SHARP AR 5320 PHPTO COPIER ERROR H-4
fuser error which could be a number of issues , press green copy button for sub-code
Aug 19, 2014 | Sharp AR-5320 Black and White Copier
I am using Sharp Copier Model no: AR-5320 and when i replace catridge it showing F2 Please give me the solution?
F2-04- Improper cartridge (destination error, life cycle error)
Identification error
model error
type error
destination error
data abnormality
Misc error
Dec 30, 2010 | Sharp AR-5320 Black and White Copier
Problem for Sharp AR-5320
The Fault fuzer. Possible faults of the block of the fastening the scene or in contact of the join or in signal of the controller of the direct current.
Address please in service Sharp
H2 00 Fusing unit temperature error 01 Fusing unit temperature error H3 00 Overheated fusing unit 01 Overheated fusing unit H4 00 The fusing unit doesn't heat up 01 The fusing unit doesn't heat up H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error
Oct 08, 2009 | Sharp AR-5320 Black and White Copier
Sharp 5320 H2 error code
this is a fuser error message. You must fix the problem causing the fuser to post an error. Then clear the message.
Jun 19, 2009 | Sharp AR-5320 Black and White Copier
Model AR 5320E. Giving H2 error.
As we needed our copier very quick we had to call a qualified person to arrange the system.
Kind regards
Miriam4177
Jun 17, 2009 | Sharp AR-5320 Black and White Copier
Sharp AR-5320 Copier giving L 4 error alternately
The only way to corret the problem is to replase the fixing unit... That is what the L4 is refering to. It is not reading the correct tempurture..
Sep 20, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-5320 giving me L 4 error some time
Usually the error is caused by a main drive over load. The machine needs to be looked to determine if its the motor, power supply, or a board.
Sep 19, 2008 | Sharp AR-5320 Black and White Copier
Error h200
H2 indicates there is a fuser error.
Try resetting it by the pressing the following buttons on the display in sequence,
#, interrupt, Clear, interrupt,
display should go dead,
enter 14,
then press print, This will clear the error code
press CA to get out and return to normal.
However if there is still a problem with the fuser, the code will return. Then you may need to have a tech look at what is the problem.
Hope that helps...
Lbcoaster
Aug 05, 2008 | Sharp AR-5320 Black and White Copier
Troubleshooting for ar-5320
H2 is a fuser Error. There should be another 2 digit number that is flashing that is the 2nd part of the error code.
Without the 2nd code I cannot look up the code to narrow it down.
Let me know what the other flashing 2 digit code is and I can give you a more specific answer.
Most likely, you will need a service call to get your machine working again since the fuser unit on these machines are really not made for consumers to remove and repair.
But, there is a slight chance that you might be able to get it working again, so let me know what the 2 digits are after the H2.
Hope this helps.
Good luck.
Mac =)
(please remember to rate this answer if I have helped you. THANKS =)
Mar 28, 2008 | Sharp AR-5320 Black and White Copier
H2 error
An H2 is an indicator that the temperature sensing device is reading open, preventing the machine to warm up. There is only one way to correct this and that is to replace the thermistor, and that takes a technician. Not a hard job but a novice could get into trouble and make matters worse. Aloha, Bill Monroe
Sep 06, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5320 Black and White Copier Logo
792 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
