Question about Dremel Variable - Speed Multipro Rotary Tool 395
396 TYP1 hI NEED TEFLON COUPLING FOR 396 TYPE I
  • 1 more comment
  • Restoreman Apr 06, 2008
    Yes I have the same problem and need to obtain a teflon coupling for my Dremel 396.
  • Anonymous May 03, 2008
    I also need a teflon coupling for my dremel 395 type 3.
  • chanook Jun 04, 2008
    I have a Dremel 395 type 2 and need a nylon coupling from the motor to the spindle. Where can I buy one?
Http://www.mtmc.co.uk/product.asp?cookiecheck=yes&P_ID=33168
Posted on Jul 30, 2008
Here's a website in England that lists the part http://www.mtmc.co.uk/product.asp?cookiecheck=yes&P_ID=33168
Posted on Aug 04, 2008
    Master:
  • 619 Answers
Try to visit :
Home .Hardwares.TitanFacts.com
Posted on Jan 01, 2008
I've hooked up my danby to the faucet but the water leaks out the top how do i fix this?
You need to have the RIGHT couplings so that the inlet is secured correctly to maintain the right water pressure to the washer. A visit to the hardware shop, plumbing section could help a lot to get the right choice of coupling to mate the hose from the outlet to the machine. You can use teflon if the thread is too loose and makes a leak.
Dec 31, 2012 | Danby Dishwashers
Dehumidifier pump leaks
Try some teflon tape to tighten things up?
Aug 28, 2017 | Dehumidifiers
Hoover steam vac hose is broken
This applies to Hoover SteamVac model F5899-910.
My unit had a broken hose. I repaired the hose using duct tape and Teflon tape. The breakage seems to be due to a manufacturing error or design defect. The hose is clamped to the unit where it passes to the inside. The position of the clamp did not allow enough slack when the handle is released and the unit is wide open.
The hose coupling has a plastic latch that holds it onto the vacuum nipple. Pry it and remove the coupling. Then trim the ragged end of the hose and clean things up. Wrap the hose with some teflon tape and then tape the hose to the coupling with several turns of duct tape. Attach the hose coupling back onto the vacuum nipple.
Now you should move the clamp say an inch, so that it leaves more slack. Take the two screws out of the clamp and pry out the plastic bracket/cover that holds the clamp in place. Then move the clamp and screw the clamp back onto the bracket/cover. Then snap the bracket/cover back in place.
Take care not to put too much slack in the hose (by moving the clamp too far), as the hose can also bunch up due to being too crowded when the handle is upright.
Inspect the hose and the tape whenever you use it.
Aug 03, 2012 | Hoover F5899-910 SteamVac Vacuum
The hose that feeds the water to the dishwasher has just broken away from the brass coupling and flooded the kitchen.
Unscrew the coupling and replace the entire hose and coupling. Use 2 flat wraps of teflon tape on the threads.
May 13, 2011 | Dishwashers
Hi i have two hp2015 ans the printer has started to smear the ink on the rollers, would the fuser need replacing or is it the paper type?
The function of Fuser (covered by Teflon sheet) is to heat the paper in order to fuse the toner to the paper. Toner sometimes smears after the print 1. If the fuser is not heating properly, 2. Teflon (Fuser sleeve) is damaged or 3 Paper is thick (Card). If you are using normal paper, then it could be the fuser.
Hope it helps! Good Luck!
CreativeTECH
Feb 04, 2011 | Office Equipment & Supplies
Dremel moto tool model 395 coupling from motor to
The part that goes between the motor and the chuck is called the CLUTCH UNIT,
REF 2615294309 it is a splined rubberised sleeve, it also fits the 276 and 396.
The price is £3.69 (including vat at17.5%) and can be obtained from Jaymac (Derby) Ltd.
http://www.dremel-direct.com/acatalog/service.html
Jul 19, 2010 | Dremel 395 Variable Speed Multipro Rotary...
Breville JE90J juice fountain spare part
The coupling on the juicer basket end is no big problem, but the coupling on the motor end is a big problem as you need to stop the motor from rotating to unscrew the coupling. This means remiving the base of the juicer which may be difficult because of the type of screws involved.
JE90/06 DRIVE COUPLING,
JE95/26 FILTER BASKET & DRIVE COUPLING
If you email me at sales@ewingelectrical.com.au I can help you with prices etc.
Mar 28, 2009 | Breville JE3 Juicer
Digital readout 396 scanner
http://marksscanners.com/396/396.shtml
Feb 02, 2009 | Uniden BC92XLT Handheld Scanner
Dremel Variable - Speed Multipro Rotary Tool 395 Logo
850 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Daniel Dollive
Daniel Dollive
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
