Question about Logitech ChillStream Game Pad
Buttons all wrong
Hi, I bought a Chillstream game pad and I'm trying to play PES 6, but my LT and RT buttons infront is working as the Z Axis and in the game you use that buttons to dash with and whatever, but I dash with my Start button and switch between players with my back button. I tryed to calibrate it, but with no luck. The start and back buttons are buttons 7 and 8, is'nt LT and RT suppose to be no. 7 and 8.
If you could help, would be great.
Thanks
Herman
  • 4 more comments
  • Vasoooo Feb 19, 2008
    Hi, I have the exact same problem. Not only with PES, but with many other games too like Madden 08.
  • Mj?lnir Smothers
    Mj?lnir Smothers Apr 08, 2008
    i am trying to play san andreas and i cant get any extra buttons, HELP i hav the same issue RT and LT are back and start
  • Anonymous Apr 10, 2008
    I have the same problem. I noticed that the buttons were mapped properly before I install Vista service pack #1. I'm on Vista 64.
  • tidus248 Oct 28, 2008
    The same thing is happening to me, I am trying to play Metal gear solid 2 on PC, and it show them like the z axis,and cannot change it properly, what do i do?
  • Anonymous Jan 03, 2009
    my front buttons don't work and my bottom joystick doesn't work either, i play bf2.
  • svetiboy Mar 24, 2009
    Same problem. In games like Psychonauts, Warriors Orochi, etc. I either can't map the right stick and/or L2, R2. Tried everything I could think of but nothing helped so far. OS is Vista32.
    Welcome Back:
    Visited the website for 2 consecutive days.
Download and use ControlMKv0232 Mapper
Posted on Mar 30, 2009
No solution but an answer on the logitech forums was:
"With the Chillstream for PC, the support of the gamepade depends entirely on the game programmer. This is because the Chillstream is a XInput device and depends on proper configuration by the game itself (This is the way that Microsoft built the DirectInput library)."
Posted on Mar 24, 2009
Mee too
Posted on Mar 15, 2008
Want to reset my xbox to new
There are different codes to insert at the system info page to reset your console to factory setting, depending on your console it may or not may work.
heres 3 examples, buttons has to be entered in sequence, directions are for the d-pad:
LT RT X Y LB RB Down Y Up Down Down Down Down Down
LT RT X Y LB RB Up Y Y X
LT RT X Y LB RB Up LB LB X
Jan 09, 2014 | Microsoft (X-Box) P5F-00001 Xbox 360...
I dont know my pass code of my family setting on my console
hey this is what worked for me. take out your hard drive so you dont wipe the memory from it (it is on the side of the xbox It says HDD on it). you do this by pressing the gray button, and sliding it out. then turn on your xbox and go to the system tab then select console settings then system info then enter this LT,RT,X,Y,LB,RB,Y, HOLD LEFT STICK IN and push X,X. There are a few slightly different codes depending on the serial number because my sons xbox has a different code, LT,RT,X,Y,LB,RB,Y,HOLD LEFT STICK IN and push Y,Y. also my friends xbox has this code LT,RT,X,Y,LB,RB,D-PAD UP, A,X,A. as you have probably noticed the only difference is the last 4 buttons but if you try a few different combinations you should get it. it can be one of either a D-pad or left stick direction, Left or right stick 'push', or A, B, X or Y i think so just play around it is the only way unless you call microsoft.
hope this helps
Nov 15, 2010 | Video Game Consoles & Games
My right mini joystick's x-axis is slightly off center so that when i play th elder scrolls 4: Oblivion, my character is always running sideways to the right. how do i fix this and is this possibly a...
i just thought i'd post here in case someone runs into the same problem
Problem: right thumbstick consistently inputs positive x-axis data ie. the thumbstick moves right on it's own
to fix this you simply:
1) remove batteries
2) hold buttons 6, 8, and 1
3) reinsert batteries while holding the above 3 buttons
4) confirm that the thumbstick is working properly
thats it...
a few forum searches have said that the buttons to hold are 5, 7 and 1... that is not true. 6, 8 and 1 are the correct buttons to hold
Jan 31, 2010 | Logitech WingMan Cordless Rumblepad Game...
Fifa 08
hi this is the solution,follow carefully and install the driver.http://xbcd360guide.50webs.com/download.html
Jun 24, 2008 | Logitech ChillStream Game Pad
Logitech chillstream
رجاء اريد ان العب لعبة بلاي ستيشن انا ف ر ح
May 18, 2008 | Logitech ChillStream Game Pad
Button uses in Resident Evil 4
You can run the setuptool.exe on the game´s folder... You can change the controls there.
However, since there´s no explanation on the numbers...
R.Ctrl=1
F=2 and 4(the "Playing Manual 3" in the game mentions that the button number 4 is used to command Ashley. However, in-game commands such as Hide are shown as controlled by the button 2. It´s strange, but F is both)
Enter=3
L.Shift=5
R.Shift=6
By the way, if you don´t know about this: I opens the inventory and M opens the map. To exit the game, you have to press Esc, go to "RETRY or LOAD", and select "GAME RESET". Then, you can exit the game.
Apr 09, 2008 | Logitech ChillStream Game Pad
No QB vison with chill stream game pad on new maddens HELP
you need a new controller this one does not work well with any madden game. I returned mine good luck
Jan 04, 2008 | Logitech ChillStream Game Pad
Logitech ChillStream Game Pad Logo
1,208 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
