Question about Samsung SCX-4100 All-In-One Laser Printer
Scanner error my printer made a terrible noise and now does not scan or photocopy. it says there is a scanner problem on the display pad. can somebody help.
  • 7 more comments
  • Anonymous Jan 06, 2008
    scanner error
  • farmerbill Jan 29, 2008
    I checked for binding, everything moves freely. It will not stop at the end so the electronic stop is not working. How do I fix that ? I not sure how it is to stop there is no stop switch. Is there a photo eye ? How do it know when to stop. Is this a common problem with this model? Looks like I can get another used unit for $50 on ebay. The printer is noise but works fine. Total pages printed137 scaned 88 pages.
  • Taslim Feb 25, 2008
    When I power on then other sound and show the Scan Error, Plase
    How to solve this proble. or, nearst Samsung Service Center,
    My office in Grater Kailash.
    Thanking you.
    Dhawan Glass Works
  • jaderi Apr 03, 2008
    I have problem with scaner ..... it is tring to get back to its intial position but it faild
    at the end it gives scanner error
  • ignaciomz May 29, 2008
    I have open de glass. ¿Where is the sensor? There is a green cable, i think it is mass. The engine dont stop and appear scanner error. thanks
  • Anonymous Mar 11, 2009
    but where is the home position?
  • Anonymous Mar 23, 2009
    i have same problem please give a solution for this on my mail ID accounts@shreyasgroup.com
    Thanking you
    Regards
    Sanjay Pawar
    Accounts Head
  • Nagaraj shettar Apr 12, 2009
    In have also cleaned the platen glass in and out, I will be able to get copies sometimes. But still the problem same repeats and I also couldn't find the sensor. Please help.
  • ignaciomz May 11, 2010
    Problem Solver:
  • 15 Answers
It is a combination fault. There is no sensor, the scanner reads the black shape on the under side of the glass pane.
What you need to do is adjust the metal earthing stop just rear of the motor by bending it with your finger. Then disturb all of the connections by unplugging the power, data and earth wires at both ends (apart from the motor power as it is soldered on at the motor end. It really comes down to trial and error, but i've just fixed mine using the steps above.
Posted on Jun 20, 2009
I have not printer cd.mary cd kho gay hai. mana apna computer kha formet mar vdiya tha . muza kham hai.
Posted on Mar 06, 2008
    Problem Solver:
  • 12 Answers
SOUNDS LIKE GEAR OR CABLE HAS SHIPED OR COME LOSE NEED TO REMOVE THE GLASS AND CHECK THE SCANER RAILS ALLSO CK TO SEE IF HOME POSITION SENSOR IS WORKING
Posted on Dec 31, 2007
Error E8 HP Laserjet MP1136
See this... http://h30434.www3.hp.com/t5/Other-Printing-Questions/m1132-hp-printer-gives-me-e8-error-code-is-it-expensive-too/td-p/907661
Jul 04, 2014 | HP Office Equipment & Supplies
Epson l200 ink pad error
epson L200 ink pads error Epson L200 is an All-In-One printer, All-In-One printer is a printer unit has multiple function as Scanning, Photocopying, and printing. Epson L200 comes with 6 ink bottle consist of 3 Black Ink, and colored ink, 1 bottle for Cyan, 1 bottle for Magenta, and 1 bottle for Yellow Colors pls check epson L200 ink pads error reset http://www.2012teamtech.com/epson-l200-ink-pads-error
Dec 25, 2013 | Epson L200 Original Continuous Ink Tank...
INK PADS FULL
get the ink reset utility with key
May 02, 2013 | Epson L200 Original Continuous Ink Tank...
Scanner error 14
the problem with scanner assembly
Mar 20, 2013 | HP LaserJet M1120 MFP All-In-One Printer
WHEN I TRY TO PHOTOCOPY ALREADY DISPLAY SCANNER ERROR 12
Scanner error
The device has detected a scan module error
Turn the device off and then on again.
Jul 21, 2011 | HP LaserJet M1005 Printer
My hp deskjet f2280 printer does not photocopy. It displays an "E" error message, always.
I have got exactly the same problem. E shown. F2280 does not copy. Otherwise it prints and scan request from PC working.
I do hope, somebody reads the question, understands what is said and has a solution. Thanks in advance. AOS
Jan 23, 2011 | HP DeskJet F380 All-In-One Printer
Hello, The scanner & photocopier were not working and the screen was just stuck on the "scanner bulb warming up". Then, after days of trouble shooting, it finally began making a noise,...
From what you described it sounds like you need to get the "scanner assembly" replaced.
The bulb is probably bad and won't come on to full power.
Not knowing what kind of printer you have, probably won't change the fix. If you can look at the event log you may be able to see an error code which could make it a definite scanner assembly replacement.
If you want to throw money at this unknown printer, get a tech to look at it and give you an estimate.
Jan 17, 2011 | Office Equipment & Supplies
My canon mp160 printer is not printing not scanning and not photocopying. When i on the switch alarm light flashes and the displays E 4 2 . plzzzz help me in solving this problem
E42 is a scanner error, it can be caused by the scanner cables not being seated correctly. If you can get the right cover off, unplug, inspect and reseat the cables going to the scanner
Sep 20, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Printer/scanner/photocopier. scanner not working. Any ideas?
Are you scanning to your computer? If you are getting an error during the transfer to your computer, check your firewall. I had a scanner (mine is a Panasonic) problem with the transfer to my computer. I corrected it by printing the properties of the scanner and found out the port number that the scanner used and opened the port in the firewall. Hope it helps.
May 04, 2009 | Office Equipment & Supplies
Scanner & black pages
The black printing usualy occurs when there is a faillure in the light, since your light is working fine, there may be a problem in the imaging device inside(camera) or the reflector. There is nothing wrong with the cartridge.
May 05, 2007 | HP PSC 1510 All-In-One InkJet Printer
Samsung SCX-4100 All-In-One Laser Printer Logo
566 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
