Question about Sharp R-1480 Microwave Oven
Sharp Microwave Oven Corousel
I have replaced the fuse, and swithc on the oven it comes ok. As soon as I enter the time then when I press Start the fuse dead again. I tried using 13Amps fuse it works but humming is coming. I tried using 10 Amps fuse then immediately after pressing the start it goes off and the fuse dead. Please answer me at
  • 4 more comments
  • Ajaz Ahhmed Dec 31, 2007
    Thank a lot for your immediate reply. I will update you as soon as I solve the problem.
  • Ajaz Ahhmed Jan 01, 2008
    I have a doubt how come it is working if I use 13 Amps Fuse instead of 10 Amps. I see the oven was running with Humming sound. Any suggestions..
    The old Fuse is M10A and I fix F10A then the fuse burnt. I tried 13A it is working but humming sound is coming and fuse is ok we tried this for 30 seconds with anything keeping in the oven. Since it is humming I thought it is better to use only 10Ams. Also I like to know M10A and F10A are both same or any difference ?
    Thanks a lot for your help.
    What if the oven is working ok with 13 Amps fuse, can I continue using oven without fear or I have to use only 10Amps fuse?
  • Ajaz Ahhmed Jan 05, 2008
    Thank u all for your openion. I able to figure out the problem and the problem was with Double Diode between the Capacitor terminals (1 and 3).
  • Anonymous Mar 13, 2014
    hkhke turn table on my sharp corousel microwave: model #209hk was working and then all of a sudden it stop. There is a humming noise when i set it to come on everything else is working fine. how do i try to
  • Sharp Master
  • 9,098 Answers
I replied privately to this, stating it may be the HV capacitor, or possibly the magnetron or transformer and giving links.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 31, 2007
  • 1 more comment
  • William Miller
    William Miller Dec 31, 2007
  • William Miller
    William Miller Jan 01, 2008
    It should use a 15 or 20A fuse. There should be a warning label near the fuse holder.
    When everything's working right, it will draw a certain amount of current.
    Depending on the nature of the failure, it may draw more or less current.
    For example, if something is shorted, it will draw more and if the magnetron is not starting, it will draw less.
    Hope that explains that part of it.
  • William Miller
    Sorry, I did not know you were outside the US.
    So I assume you are using this on 220V with an adapter or step-down transformer?
    If so, I would want to be sure the step-down transformer is working properly. If you have another one, you could try it.
    If the problem lies in the micreowave, I would say it is the high voltage transformer, but going beyond this level of diagnosis is difficult to do remotely.
I have a sharp carousel over the range microwave oven R-1505LK no power the outlet is ok did lose power to the house and the microwave didnt come back on where is the fuse located
The fuse is usually located inside the cover near where the power cord enters...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
Nov 16, 2010 | Sharp R-1505 Microwave Oven
Microwave will not work
Even though you don't mention the model number, you posted under Sharp model R-1491, so I'll assume that's it.
You say when trying to work the actual microwave, you get nothing?
We could use a little clarification, but FixYa only gives you one shot at posting a help request.
When you enter the cooking time and press "Start", if the timer counts down and the oven lamp comes on, but the the turntable, cooling fan, and microwave section do not run, then you have a bad secondary interlock (bottom door switch) or its mount is bad.
We have the applicable service manuals for these models and have uploaded it to our site here and here to help you.
Also look at this info on door switch diagnosis and replacement.
Hope this helps.
William E. Miller, AS-EET
Microwave Oven Control Panel Repair Nationwide
May 30, 2010 | Sharp R-1491 Microwave Oven
Microwave oven Sharp R-305H does not come on. Breakers OK.
check the fuse on the floor of the oven ... near where the cord enters the cabinet
Oct 29, 2009 | Sharp Microwave Ovens
Sharp Microwave Oven Timer Counts Down Very Fast (Demo mode)
Here is where you can download the manual
Yes the problem can be undone also.
Feb 09, 2009 | Sharp R-540DK Microwave Oven
Emerson Microwave MW8115SS
there is a thermal fuse inside that is likely blown.
easy to replace just have to google bullet thermal fuse.
May 11, 2008 | Microwave Ovens
Sharp R-9H66C Microwave Convection blowing fuses
check high voltage transformer and high voltage diodes, condencer, and magnetron.,
Oct 27, 2007 | Sharp R-963 Convection/Microwave Oven
Sharp R-9H56 Microwave convection oven
I have this model. Press clear then press Auto/Clock. Enter in the time eg 700 then press Auto/Clock again. The time should now be set
Jun 08, 2007 | Sharp R-1872 Convection/Microwave Oven
Sharp R-1480 Microwave Oven Logo
204 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
