Dometic RM2652 Refrigerator
Problem for Dometic RM2652 Refrigerator
The refr. rm2652 is staying
By glotec1wc on Oct 24, 2009
the refr. rm2652 is staying to cold and freezing up water also
Solution #1
posted on Oct 24, 2009
Not Rated)
MNfisherman
Rank: Wiz
Rating: 84%, 2709 votes
Set to a lower setting. If it is not getting any warmer, the temp control unit or defrost timer is bad. You can test with an ohmmeter.
Popular Solutions for Dometic RM2652 Refrigerator
Questions and Unsolved Problems for Dometic RM2652 Refrigerator
Do you recommend Dometic RM2652 Refrigerator?
Answer
Answer
unit will only work on gas on RM2652
Answer
AC input power to fridge doesn't work. DC Power / Gas does work. Fuses are good on control board.... (More)
Answer
Freezer works on 110 volts and propane but refreg doesnt work on either
Answer
refrigerator only runs on gas, when set to auto, it trips the GFI plug. I was told about a defrost... (More)
Answer
How do you regulate Dometic to stay at 36 degrees. Our Dometic gets down to 26 and 24 degrees, which... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dometic RM2652 Refrigerator:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 1220
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(650) 616-9292
Refrigeration Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
