Question about Samsung Digimax S700 Digital Camera
SAMSUNG DIGIMAX A 7
CAMERA WHEN TURNED ON ,,LENZ OES OUT ,,GREEN LIGHT FLSHES AND BLEEPS 3 TIMES ,,PLEASE CAN OU TELL ME HOW TO FIX IT?
THANKS
TANYA
  • brada12as Jun 20, 2008
    halo i have same problem camera do'not start just biping bad noice tri timeand shot down
  • 57 Answers
Sounds like a power issue. Make sure you use the recommended batteries. Also, some cameras have settings to where you need to change it in accordance to the type of batteries you are using. exp. alkaline, ni'mh, etc.
Posted on May 27, 2008
My Samsung Digimax S800 Camera, when push power bottom, the camera green lite near power button and camera bleeps twice. Then turn off. Zoom len is fully extended. Chnage Battery three times.
this problem is a is usual occurrence when the camera is not well powered.
ie. the battery might not have enough charge on it or might have gone bad and require you to replacei it.
please ensure you get the battery with right voltage and wattage, the required is usually written around or in the battery compartment.
Jan 14, 2011 | Samsung Digimax S800 Digital Camera
The lens gets stuck out and the little green light bleeps but it won't work or turn on -.- what do i do?!??!!?
Put in fresh batteries in your camera and try to power on. If this didn't work, to do this little trick:
1. Hold the camera on your right hand with the lens facing the ground.
2. As you press the power on button, tap or hit the camera's base to your left palm. Do this several times.
Chances are, there could be a sand or granule of dust that got stuck on the sides of the lens, preventing it to retract properly.
Hope this helps.
Dec 14, 2009 | Samsung Digimax S500 Digital Camera
Samsung S760 Digital Camera - Not turning on and lenz stuck out.
Yes you are correct lens is struck
* Carefully inspect around it for dirt or debris
* If you see any dirt or debris around the lens, use canned air to gently blow it away
* After removing dirt and debris, turn the camera on and off
This should work
Hope this helps .
If your problem still continues you need to take to service center .
Thanks for using FIxya
SAM ANDERSON
Jan 30, 2009 | Samsung S760 Digital Camera
Camera has a black screen when turned on
In some cases there are only oxidized battery contacts, to treat with a little bit sillicon grease on the battery contacts gives a long lasting protect against. moist., otherwise there could bad soldering but in practice i have never on camera,s have problems with it BUT another suggestion are the little motors to operate the diaphragm and zoom mechanic can be the problem if its hanging and if one of the motors is hanging there could be a miss timing and then the electronical protection turns it off off. was my first Samsung experience with a camcorder of the brand 23 years ago there could be a dirty mode select switch or little microswitch on it, but in most cases the batteries.
Aug 02, 2017 | Samsung Digimax A503 Digital Camera
It dont turn on
dont buy this c*#p again thats the best solution i can give
Jun 23, 2008 | Samsung Digimax S700 Digital Camera
Samsung digimax D103 10 million pixel camera
This product has a 2 year warranty, unfortunately I lost the original till receipt, but managed to get the transaction details from PC World (I bought it in Dec 2006). The Samsung telephone number for the UK is 00800 12263727 - I have now sent it off to them for repair (recorded delivery) to the service centre at Samsung Opto-Electronics UK Ltd, Samsung House, 1000 Hillswood Drive, Hillswood Business Park, Chertsey, KT16 0PS - On talking to their service team, when the camera "Beeps" 3 times and turns off it is faulty, and will need to be repaired - So no easy fix - It's over to you now!!
Feb 13, 2008 | Samsung Digimax A7 Digital Camera
Digimax l60
I don't know, it's not powering up......
Jan 03, 2008 | Samsung Digimax L60 Digital Camera
Camera not working
Usually when the camera beeps 3 times. It means the battery is low. Then it turns right off. What kind of batteries are you using for your camera?
Dec 27, 2007 | Samsung Digimax S630 Digital Camera
TROUBLESHOOTING
Samsung User Support will advise whether this is replaceable under warranty or a recall for faulty manufacture
Dec 26, 2007 | Samsung Digimax A7 Digital Camera
Cameras lense open, camera off, when turned on it bleeps and turns itself off
i have exactly the same problem with exactly the same camera. It happened to me once before but by 'fiddling' with it, it seemed to catch back in place and turn on again. but this time it wont work. seems like a design fauly from samsung?
Nov 08, 2006 | Samsung Digimax V800 Digital Camera
Samsung Digimax S700 Digital Camera Logo
49 people viewed this question
Top Samsung Cameras Experts
Computer Links
Jerry Z
Are you a Samsung Camera Expert? Answer questions, earn points and help others
