Purchased a Maytag Gemini MER6770 in 2000. It randomly beeps (one beep only per time), sometimes once every few hours or once every few minutes. No error codes appear. When it beeps when the oven is on, the oven shuts off. I have to keep turning it back on. It beeps when the oven is off too. I am assuming the beep indicates the oven has turned itself off, even when it is already off. Help!
Sounds like the cancel (or stop) button is making contact by itself. Clock (oven control board) may need replacement. One option to buy it new, your part number is 12001661 Coupon "New10" chops 10% off. Another is to send the clock to be rebuilt. Google "stove timer rebuild", you'll find plenty of companies which can repair your original clock. In case you need it, the original part number is 74004542. To get to the clock, remove the back of the control panel. Good luck.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Maytag MER6772 Gemini Electric
I have two problems. The cleaning instructions say to lock the doors, but I see no lock. 2nd and...
(More)
I have two problems. The cleaning instructions say to lock the doors, but I see no lock. 2nd and more important, the upper oven is intermittently losing temp control. That is after reaching the set temp, it fails to maintain that temp. It falls back into the mid 200's
I have Gas/convection range puchased 1999. It started acting up a couple of years ago, turning off...
(More)
I have Gas/convection range puchased 1999. It started acting up a couple of years ago, turning off on its own and going into lock mode. Recently it start flashing F5 and then would go off. We have had the components replaced twice with no luck in repairing this problem. We recently had FC come up. The service man seems to be at a loss. Any ideas would be appreciated.
admiral designer series model df456570 glass top cracked, could this be replaced if yes from where I...
(More)
admiral designer series model df456570 glass top cracked, could this be replaced if yes from where I can get it???
