The belt is probably stretched and not turning against the resistance of the carpet. You can get a replacement belt here: http://vacbelts.com/hoover-windtunnel-38528-035-belt.htm
That probably stretched the drive belt and now it won't turn against the resistance of the carpet. You can get a replacement belt here: http://vacbelts.com/hoover-windtunnel-38528-035-belt.htm
Your belt is stretched or worn and therefore cannot turn against the resistance of the carpet. If you replace the belt it will fix the problem. You can get the belt you need here:
The motor reset keeps tripping after just a few minutes of operation. I have cleaned all filters...
(More)(More)
The motor reset keeps tripping after just a few minutes of operation. I have cleaned all filters thoroughly, checked for free movement of brush and motor sounds fine- is not laboring, suction is moderate. Model is actually UH70085
Posted. Thank You!
Congrats on your 3 solution. You're helping others! Someone may even thank you with a Testimonial.
The belt keeps coming off. There is a little U shaped metal piece that came off when the belt first...
(More)(More)
The belt keeps coming off. There is a little U shaped metal piece that came off when the belt first came off. Where does it go? When we first got the vacuum, we sucked something up and the belt came off and that little metal piece fell out. The belt now periodically comes off when we bump something. Please help us!!!!!!!!!!!!
Posted. Thank You!
I need to replace the carpet/hard floor switch on a hoover windtunnel. How do you dis-assemble the...
(More)(More)
I need to replace the carpet/hard floor switch on a hoover windtunnel. How do you dis-assemble the case?
Posted. Thank You!
my hoover alyx 2000w became too noisy.. the noise comes from the top small spot on the cyclone...
(More)(More)
my hoover alyx 2000w became too noisy.. the noise comes from the top small spot on the cyclone system pot, when i cover it with my finger it goes away so the problem is there
Posted. Thank You!
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
