Question about AMD BOSTAR M7ViZ Socket A Motherboard (MBM7VIZ)
Wiring issue new case need wiring assistance. do not know what goes where, lost motherboard book.
    Sniper:
  • 74 Answers
Www.biostar-usa.com/docsmain.asp try here.....good luck..
Posted on Dec 31, 2007
I am going to be fitting a new motherboard, and I am worried about fitting in the power and the wires? Any advice??
There are only a few things that must be carefully observed when changing out motherboards. The first is to ensure that the mounting lugs match up with the mounting holes on the new board. Remove any that don't, otherwise they may short out the motherboard. The new motherboard will come with a book that will show the external connections that must be made from the case to the motherboard. Most cases have labeled plugs that will correspond to the information in the manual. There are two plugs that can be confused - Power Switch and Power LED. Power switch is used to turn on the machine, Power LED goes to the green light on the front of the case. Alos, the HDD LED and Power LED connections are polarized, meaning they have a + and a - wire. The Power LED wires on most cases will be green and white with the green wire being the +. The HDD wires on most cases will be Red and White with the Red being the +. If you get them reversed, it will not harm the machine, but the LED will not work and you will have to turn the plug around. The plugs for the power switch, reset switch and speaker (optional) are not position dependent and cannot be installed backwards. The large power connector to the motherboard is keyed and cannot be installed backward. They can, however be very difficult to connect fully and may required forceful pressure to seat. If this is the case, place something firm, but non-conductive under the edge of the motherboard below the socket to prevent cracking the motherboard. Also, while this may seem silly, some people accidentally do it, so I'll say it here, do NOT have the power supply plugged in when making any connections to the motherboard or when installing or removing any expansion cards.
Jan 13, 2012 | ASUS P5GC-MX/1333 Motherboard
I FORGOT MY PASSPORT NUMBER MY NAME GOVURU PRAVEEN REQUIRD ARRGENTLY
FixYa does not issues passports and cannot assist you.
You need to go to the passport Office in your city and get a new passport. You need to take some identification with you such as your birth certificate, drivers license, bank book etc.
Dec 06, 2010 | Intel Motherboard
I lost my Motherboard book and I need Diagram to put motherboard into new case
Can you elaborate further - what motherboard you have, what case is it, I will try and help.
Oct 29, 2010 | HP Compaq Motherboard
Problem with panel front conector in Dell Dimension 2200 motherbo
The following information is to assist you in performing the right connections. You should take precautionary measures such as grounding yourself and completely disconnecting the PC form any source of power.
This picture shows the connector for the front panel power button, reset button, and power and hard disk lights: an 8x2 pin connector with 1 pin missing:
The table below lists the pinouts for the connector. The orientation of this table is the same as the picture above, this shows the top part of the connector. All the pins below pin 8 appear to be non-connected.
Each pair of pins labeled Power and Reset goes to the 2 wires for the corresponding button. The hard disk and power LED wires connect to the corresponding LEDs, you need to ensure the proper polarity of the + and - wires for each LED or it will not illuminate.
The above information is for your information only.
Mar 01, 2010 | Dell (2M502) Motherboard
Connection of wiring to board
6a98a1a.jpg For the usb connectors you can follow the diagram above:
For the rest of the connectors I need to know the model number of your motherboard
Nov 23, 2008 | Computers & Internet
Regarding Motherboard
hey, the easyest way to figure out what motherboard you got is to look inside the case and see the model written on the motherboard or get a program like everest home, its available at http://www.majorgeeks.com/download4181.html
let me know if you require further assistance.
Thanks,
Ekse
Sep 05, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Dell motherboard
If you mean the front panel power switch the connectors are in most cases located in the bottom right corner as below:
Note that your wire setup can be difrent form the image.
If you need more assistance let me know, I'm here to help
Apr 13, 2008 | Computers & Internet
SL-75KAV
Here ya go http://www.motherboards.org/files/manuals/118/75kav.pdf
This has all the pictures you will need to reconnect everything. If this helps be sure to rate my help.
Jan 22, 2008 | Computers & Internet
Motherboard issues L7VMM3
i thin if u have screwed up with connection u might have screwed up the motherboard is the mother board workig if not ur power in inthe mother have gone dead
Oct 18, 2007 | Computers & Internet
AMD BOSTAR M7ViZ Socket A Motherboard (MBM7VIZ) Logo
47 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
David
David
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
