Question about Ejay DJ Mix Station (djmix) for PC
Xml error Hi, I have the same problem as the first post. invalid skin file (error line %1 in the xml)
SOURCE: dj mix station 3
i have installed the mix station 3...i am applying the serial number its getting invalid..what to do plz advice or give solution...
Posted on Aug 19, 2009
0 characters
1 Points
Error 115 when installing Adobe FrameMaker 7.0 or 7.1 on Windows
Do one of the following solutions:
Solution 1:Disable anti-virus applications, and make sure all 3rd party applications are closed before installing.
Solution 2:Copy install files to HDD are run setup from that location (Frame installer lives in FM directory)
Solution 3: Remove all files from %temp% and %windir%\temp and reinstall
Background information
Error 115 from the InstallShield help reads as follows: "Specified file cannot be opened as write. An attempt was made to overwrite a locked file belonging to a file group that does not have the Potentially Locked or Shared property set to Yes; an attempt was made to install a file with a long file name (or to a folder with a long path name) in a 16-bit setup; or the path to the target folder is invalid."
Apr 10, 2011 | Adobe PageMaker V7.0.2 for PC
Flash MX 2004 configuration
there are few steps you can try
Create a fresh Login ID for your Windows OS
Login with new ID
Increase your Virtual Memory
remove the slack files in Temp folder, You can use ccleaner addition to disk clean up.
Secure the registry changes, (you may you use spybot tea timer)
Please let me know the details, like your current operating system, RAM, CPU, Exact version of your Flash MX
Good Luck
Mar 24, 2008 | Macromedia Flash MX
Hello: I have Adobe Photoshop Elements 6.0,Windows XP with Pentium 2.8Gz and 1.59RAM. I set off on a mission to organize family pics but Photoshop Elements is driving me crazy due to several...
whats Graffi\'s automatic program, it sound like this program is incompatible with adobe photoshop elements. what format wereyour original files before you opened them in phtotoshop elements?
Feb 02, 2011 | Adobe Photoshop Elements 6: Windows
Error loading skin on roxio 10- everything else works but making dvd
This error is usually caused by corrupted MSXSL 4.0 files. Download and install the latest XML 4.0 update from Microsoft. Please refer to the link below:
Cheers . . .
May 21, 2010 | Roxio Easy Media Creator 10 Suite
Itunes wont open and says cant find needed file?
This usually happens when you have either renamed the file, moved the file somwhere else, or deleted it all together. Sometimes you may forget editing the filename or moving it to a subfolder.
Whenever you do this be sure to go to itunes and either add the file again and delete the old one from the database or "Get Info" and update the current file. tho u ve not mentioned any specific name of the file i m tryin to give u an example..suppose u are cant locate the music file m sure the files are where they are supposed to be then they must have been renamed. You can verify this - Find a track with an exclamation mark next to it
Open your iTunes Music Library.xml file with Notepad (the iTunes Music Library.xml file is usually in C:\Documents and Settings\YOURNAME\My Documents\My Music\iTunes).
Search for the track name
A dozen or so lines below the track name will be the full path to the file and the filename.
Compare this to where you know the file to be. If it is different then that would show that something/someone has moved/renamed the file. hope u will b sorted out wth ur problem... all the best regards.
Jul 15, 2009 | Apple iTunes
How do I load several swf files and use 1 xml?
The easiest solution is to put all flash files in sub-folders, and link them in Dreamweaver from the files in the root folder --- but the key, AFTER uploading to your server, is to change your MANAGE SITE CONTENT information with your host server. Specifically, change (advanced) PERMISSIONS to READ and EXECUTE (DIRECTORY). It's important that both are checked… If you don't do this you'll see that it works fine on your local machine, but not after uploading to your server.
May 12, 2009 | Macromedia Flash MX
Cannot complete installation of or remove adobe 8.1.1
This solution has helped a lot of people. The cause of the problem has
been known already and is explained clearly how to fix the issue on the
site link below.
'Invalid Drive during installation
Fixing Invalid Drive Error 1327
Jan 28, 2009 | Adobe Acrobat 7.0 for PC
If you are making desktop application u need 3rd party flash software like mdm zinc or flashjester jugglor. it provides easy way to write on files. If you are developing web you need to use either php / asp which ever u know. If you know nothing better is doing in php. its easy and powerful. See below for sample php code. to send from flash you have to use sendToURL(request); in AS 3.0
$fileName = $_POST["filename"];
$xmlContents = $_POST["xmlcontents"];
$lastBackslashPos = strpos ($xmlContents, “\\”);
while($lastBackslashPos >0){
$xmlContents = substr($xmlContents,0,$lastBackslashPos)
$fh = fopen($fileName, “w”);
fwrite($fh, $xmlContents);
Mar 06, 2008 | Virtual Training Company Macromedia Flash...
Dj mix station 3
Dec 10, 2007 | Ejay DJ Mix Station (djmix) for PC
Plat swf files sequentionally from xml
I've finished your requirement almost but how do you read the swf files from the xml one by one? My code will parse the xml and open the swf files one by one and so you can only view the last swf file.
var myXML:XML=new XML();
        for(var aNode:XMLNode = this.firstChild.firstChild;aNode!=null;aNode=aNode.nextSibling){
And your sampleFiles.xml should look like this:
Oct 08, 2007 | Macromedia Flash MX
Ejay DJ Mix Station (djmix) for PC Logo
Top Ejay Graphics Publishing, Design & Multimedia Software Experts
Are you an Ejay Graphics Publishing, Design and Multimedia Software Expert? Answer questions, earn points and help others
