Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Odd fault codes then stops working.
My machine first completed a wash and dry with the two lights flashing for "blocked filter" ('Eco' & ''Prewash). There was water still in the machine but I cleaned the filters although they were clean. Did an on/off reset, next the the 'Eco' & 'Fast' lights were flashing (no code in book for this). On/off reset again.
Now it will fill and boil water without doing anything. It will drain if I start gain.
Any ideas?
  • Anonymous Jan 05, 2008
    Very same problem as well any suggestions ?
  • 108 Answers
I had a hotpoint engineer try to fix this type of problem.
He insisted that there was something stuck in the bottom of the filter or pump.
Sure enough there was.
1. Unplug your dishwaser at the wall. Check its off or disconnected.
2. Remove the grill under the bottom rack.
3. Ensure that the filter is free from food and other obstacles and clean the filter.
4. Before replacing filter etc, get a piece of metal coat hanger wire and care fully insert it down the channel under the filter to free any lodged items. You may also see a small white impleller try to turn this with your finger or the coat hanger wire (this is the info from the engineer!).
5. replace filter and retry a wash.
This routine fixed or machine twice and will hopefully fix yours!
Don't forget to rate me!
fyi
The third time about 1 year later this occured again and even hotpoint gave up as they could not fix the machine. (after multiple visits). I think that the two flashing lights are were a red herring and the dishwasher had a separate intermittent fault. Hotpoint replaced the unit for a mimum charge. Callout + 40.
Posted on Feb 28, 2008
Machine does not seem to be filling properly, then does nothing else.
Sounds like you're fill valves are junk which sadly happens allot. This video is very generic but should give you an idea
Jul 06, 2017 | Hotpoint Ariston Aquarius WD420 Front Load...
Bosch wfl 2000 problem
it is not doing what it's supposed to do.
power is not routed properly - replace the board
Jun 13, 2008 | Washing Machines
MIELE W412 PREWASH INDICATOR FLASHING
If your PreWash is flashing then you have a pressure problem. You can dry using a washer machine cleaner or doing a hot cycle with white vinegar. If that doesn't help the electronic would have to be changed.
Jan 08, 2012 | Miele W412 Front Load Washer
Flashing lights on Hotpoint FDW20P Dishwasher
No solution! tried resetting to factory defaults but ended up that even the drain pump stopped working. after flooding the kitchen (nearly). I decided it was terminal and am loking for a new dishwasher urgently as I type. Cheers.
Feb 18, 2009 | Hotpoint 24 in. DWF32P Free-standing...
Dishwasher prog light is flashing and pump is running nothing els
ok, just a few minutes after posting this as a fault, I have opened the covers, the machine has a leak, the undertray has a sensor which has detected this, flashing light (prog 45 degC wash) flashing is a code to indicate leak sensor active.
Other prog lights flashing indicate a different fault, the following details each... this is a cut/paste from another forum site, copied without permission....
jawa592rc_a04.gif on 6th Feb 2008
Cannot guarantee 100%accurate but you all might like what the flashing fault codes actually refer to, note what follows are pointers to what bit has gone wrong only. You should have the programmes running left to right: led1=intensive,led2=normal,led3=eco,led4=fast,led5=prewash,led6=delicate wash.ok so when this heap of western european tosh goes wrong one or two lights will flash this is what they mean:led3=m/ch has o/flowed water . ie the base underneath has sensed a leak.4=i/let h2o valve u/s or slow fill.5=thermister(electronic thermostat) is u/s or more likely the pcb .6=timeout heating which means the thermister senser between the door halves has become faulty or detached.3+4=no pump out,slow pump out,pcb u/s,blockage.4+5=tap off i/let valve.3+5=wash motor not coming on -seized,winding o/cic.but can also mean mesh plte filter badly blocked.1+4software fault with pcb.4+6=heating cic u/s (usually the heater tube )but can be the heater relay on pcb.3+4=pcb u/s.I don`t except any responsiblity for this being spot on or near spot on!! hope this helps someone.Try NOT to electrocute yourselves please!! If your not at all confident walk away and get "someone" who knows what they are doing.Cheers. jawa592
Jan 21, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint FDW60 Flashing lights 3 and 5
Is it possible that water has gotten inside the controls that could have caused the flashing lights? Kind of like spilling water on a calculator, everything seems to go haywire.
Jan 11, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Pre wash not happening
poss blocked filter which also controls your pressure system, on your machine I believe if the prewash ligbt is flashing it would indicate a blockage there
Jun 13, 2007 | Hotpoint WMA46 Front Load Washer
Dishwasher error codes please help
I too had this problen today. Printed off a manual from the Hotpoint website. Very helpful troubleshoot section. Anyway, flashing eco and fast lights and beeping sound indicates 'water feed pipe blocked' You need to check the water inlet connections on your tap.However, when we pulled it out we noticed the blue water inlet pipe was slightly kinked. Straightened this out and hey presto! It works fine again. How this happens when its worked ok for 18 months will never know but still. Try it! hope this was helpful...shewoo
Apr 26, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
475 people viewed this question
Top Hotpoint Dishwashers Experts
Marvin
Marvin
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
