Question about Instant Cameras
SAMSUNG MAX-S520 I'm trying to locate a repair manual on how to get our hi-fi cd-player to function. It spins the music CD's but doesn't read them.
0 characters
1 Points
Vivitar camera
Hi Lamper,
You really do not need the Cd to download the pictures. Hook up the USB cable, and turn on your Camera. Your computer should alert you that the camera is connected. Follow the directions on the computer to download your Pics. I am sure your CD was quite valuable and probably had some really cool programs to edit the photos. I like using Adobe Photoshop. I will see if I can find you a download for you a new Vivitar replacement.
Nov 04, 2007 | Instant Cameras
The red lights are flashing every time i try to take a picture.. but i changed the batterys and every thing whats wrong?
doesn't the films come out of it?
this repair is tough, recommend you to send it to shop that do camera repair
Jun 29, 2012 | Fuji instax mini 7S Film Camera
I have a Nikon F601 and I put a 400 iso film recently and I sort of didnt know how to load it on properly so I pressed the shutter release button as I loaded it twice when youre only suppose to press it...
Remove the lense, or the film if you're willing to waste it, and check to be sure the shutter blades aren't damaged. It'll be fairly evident if they are. If they are, the camera is pretty much now a paperweight. I hate to tell you that - but shutter replacements are VERY expensive and parts for most of these models no longer available from Nikon.
If that is not the issue, set the mode dial to M and try to take a shot. If that also doesn't work, either the batteries are exhausted or there is an internal issue in the camera. At this point, try new batteries. If that also gets you nowhere, you'll need to seek a reputable service tech, either through Nikon directly, locally if you can find one, or online/mail-order. If you have to go mail-order/online I'd recommend KEH Camera out of Atlanta, GA. They are very reasonable, have decent turn around, and do good work - but expect at least 1 month without your camera.
In M(anual) mode, be sure the lense is also set to M, via the switch on the front of the camera near the lense mount. You're not worrying about the quality of the image, only if the camera will take one. In manual mode, the light meter and other functions will have NO bearing on anything the camera does or doesn't do. At this point the meter reads out only for your information for you to set the settings yourself. The batteries do everything else - firing the shutter, driving the motor, etc.
Jul 21, 2011 | Nikon Instant Cameras
I require a replacement shutter mechanisum located at the bottom of the main body
I would check Ebay for someone selling a camera for parts that you can harvest parts out of. Mamiya doesn't make parts for these cameras anymore, another option is to find a master machinist that can custom fabricate a part/parts for you. You can also check with camera repair shops that might be willing to sell you the parts directly so that you can install them yourself.
Repair shops:
Other links that might work for a machinist:
Nov 02, 2010 | Mamiya C330 F Professional TLR Film Camera
Just installed windows xp and my speakers dont work
if your pc came with a motherboard cd then insert this cd an auto play will pop up run the cd from there and select all drivers everything will be installed hope this helps if it doesnt work then check the jack the speaker goes into the green jack.
Mar 08, 2010 | Linhof 4x5 Master Technika 2000 Body -...
Samsung AF Zoom 105S
dont know same prblem
Jul 04, 2008 | Instant Cameras
Easycap USB 2.0 Capture Controller HELP!!!
You will need to download
XP -
Vista -
You must then plug in your device. Then go through the driver update it will say cannnot find and ask if you have a disk click I dont then click browse my pc for drivers. open the zipped folder and extract all the files onto your desktop. Then just select desktop in the driver update and it will install :DD
Jun 18, 2008 | Instant Cameras
Open Questions:
Instant Cameras Logo
32 people viewed this question
Top Instant Cameras Experts
Steven Wander
Steven Wander
Are you an Instant Camera Expert? Answer questions, earn points and help others
