Question about Samsung SF-5100 Plain Paper Laser Fax
Samsung SF5100 has a loud buzzing noise
Our Samsung SF5100 is not presently working, it started with a cartridge jam, and when this was cleared and we re-started to get the info from the memory there is a loud buzzing (more like an alarm). The information cannot be received as it seems to stick when it reaches the cartridge, then it shows another jam, and the process starts all over again. If we leave it the alarm stops and we can send a fax, but cannot receive or retrieve from the memory.
  • salomo81 Jul 14, 2008
    i have a samsung sf5100 and it making a loud buzzing noise ploblem just after u a trying to fax,i can,t sent nor receive a fax pls help.
  • 417 Answers
Hi there you might have a faulty toner cartridge is it a original or has it been refilled? I suggest to install a new toner cartridge and hopefully that will cure the fault. If this dosen't there maybe a small piece of paper stuck in the cartridge or after the toner cartridge within the heat section open the back of the machine (the jam door) and check there is no paper.
If the printed document is getting stuck just after the toner cartridge it will most likely to be the heat section will need replacing.
Hope this helps you and please rate me
Thanks J
Posted on Dec 31, 2007
Singer Touch-tronic 2000 makes loud humming/buzzing noise, stitch selector lights quit working, needle bar stopped moving.
Sounds like you've got a thread jam going on in the bobbin case area. Good cleaning and a new needle will probably fix it. See: https://answers.yahoo.com/question/index?qid=20091202121550AAHxN8y
Apr 20, 2014 | Sewing Machines
LOUD BUZZING NOISE AND THE ANSWER I RECEIVED WAS FOR A DIFFERENT MODEL. CAN I FIX IT MYSELF?
If the loud buzzing noise is present when cooking food, the magnetron is the likely cause, some models are louder than others. But if the buzzing noise is there without the microwave running it should be checked. No! this something that should be checked by a professional for safety.
Mar 17, 2012 | GE Monogram ZEM200SF Microwave Oven
Samsung DLP4663W. Loud buzzing noise from inside
The loud buzzing is usually due to the Color wheel being broken ir the bearings being bad.You can get replacement wheel at the following link.
http://servicemanuals.vstore.ca/
Sep 12, 2009 | Televison & Video
Samsung sf5100 fax How do i replace the toner
Open front cover,then pull out toner and in the middle you will see a tiny fuse. Take it out and put a new one in. Put back toner,close everything and let it run.
Sep 11, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Loud buzzing noise
sounds like a color wheel problem, I can send you a DIY File with pictures if you wish. Contact me at techman32K@ yahoo.com. Good Luck!!
techman
Sep 05, 2009 | Samsung HCM5525W 55" Rear Projection...
Loud buzzing noise
seems the the motor is ****! avoid switching it more further to prevent its motor from burning!
motor could be stuck due to rust build-up.
or something might have jammed along the motor area or along the rotating part.
Jun 18, 2009 | Dryers
Loud buzzing noise
sounds like the color wheel needs to be replaced very easy repair on that model Samsung.
Jul 05, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Dell 942 carrier jam
This morning I replaced the cartridges in the Dell 942 printer, they jammed to the left which made a loud grinding noise and the cartridge jam error came on.
I solved the problem by turning the printer on with the top up which moved the cartridges to the right a little so I could reach back, push one down a little manually which freed them to move over to the middle.
Feb 28, 2008 | Dell 942 All-In-One InkJet Printer
Samsung ML 2510 printer won't feed paper
I have experienced the same problem . . . a little earlier this evening. I took all the inner components out, took apart the toner cartridge, I thought that the gearing was very hard to turn on it and on the inside of printer, paper feeding etc... and that is wear the loud noise is coming from. Out of desparation, I shook it to hear if anything internally was loose and there was and still is, I would not say its the best solution or by any means a permanent but you may be able to dislodge the debris from the gearing and be able to print. After it was dislodged from my printers gearing it has worked again. Though I believe it's temporary. I am looking for a guide or how-to on opening the printer casing to physically remove the debris. If you know of a guide let me know and I am sure it would help you too.
Nov 25, 2007 | Samsung ML-2510 Laser Printer
Samsung SF-5100 Plain Paper Laser Fax Logo
215 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
