Question about OKI C5200n Laser Printer
Printing with 190gsm paper
I am trying to print out calanders on 190gsm paper, but it gets stuck coming out and I can only pirnt one page, I pull the page out but the lights just flash yellow and I can not do anymore.
I have altered the size weight of paper but it still wont print more than one page.
I can not find my instructions for the printer, do you have one I can download.
My laser printer is a OKI C3300, but I can not find it in your list, so I had to put another one in there so I could send the message to you.
  • OKI Master
  • 1,113 Answers
Max paper weight is 203gsm so you are near the upper end of specs, you must feed via manual pass and exit from face up tray (out of rear), paper type(heavy/card stock) must be set on print driver. User guide can more than likely be found
Posted on Jan 02, 2008
  • Soulvisitor
    Soulvisitor Jan 02, 2008
    Set the manual bypass tray's paper type to card, via buttons on printers control panel.
    If you look at the back of machine, there is a pull out tray that is the face up tray, if open paper will exit via face up tray.
When printing documents no matter how few or how many pages, paper gets stuck in the middle of printing.
Try using regular paper on unit as specified by Samsung. If that does not resolve the issue then the hassle lies with the paper feed mechanism. Often a good cleaning of all the rollers in the path can take care of the issue.
Aug 24, 2015 | Samsung ML 2525 BW laser Printer
How to stop printing once it has started
For Brother Laser Machines. Start by pulling the paper tray out a little. This allows the page that is currently feeding through the system the chance to get through without jamming causing a whole slew of other problems.
Once the printer has stopped trying to feed the pages through coming up with an error saying paper out then you can look at deleting all the print jobs in the print queue on your computer. All but the one currently being printed should disappear when you delete them. The one that is left will be errored.
Then turn your printer off for 30 seconds closing the paper tray and try to delete that last job from the queue.
If it will not go then turn your printer back on and let the last couple of pages print out. these are pages that are stuck in the system. If the print job did disappear then just turn on your printer as normal and it should be clear of any jammed printing and you don't end up with Paper Jams in the printer to clear.
Sep 06, 2014 | Brother HL Office Equipment & Supplies
HP 2200LaserJet prints a few pages, then gets stuck
You may have a recurrent paper jam. Use a strong light to examine the entire paper path. Even a tiny fragment of paper can cause the problem you describe
Jan 27, 2013 | HP LaserJet 2200D Printer
My printer won't print letter automatically. It's stuck on printing only legal. If I pull legal tray out it will print letter. But I need it to adjust with alternating print jobs.
Printer wont stop paper, if any page length mismatch,Select page length as any size, as well as while shooting the print command select page length as legal & try it. I feel that teflon not rotating properly, result paper jamming at bottom end. If any paper length faulty printer detects the length give message of mis match..Pl check carefully...
Feb 01, 2012 | HP Laserjet M2727nf Multifunction Printer
I am printing several pages and there is a jam. I
It will re-print it after you clear the jam. Just pull it out pulling slowly and evenly and it will come out.Also you can see directions on Steven 818-888-0006
Mar 06, 2010 | HP LaserJet 3055 All-In-One Printer
My printer will not print
You have probably broken the Paper exit assembly, you can see this if you look into the slot the paper comes out off, study it carfully a roller might have been dislodged and should just pop back into place.
Aug 15, 2008 | Brother HL-2040 Laser Printer
The Paper light keeps flashing when theres paper in the printer
A few things could be happening here.
1. Clear the print queue, and if there are jobs that won't delete, reboot the computer.
2. Now clear the jobs on the printer (cancel job button) until the status light turns green.
3. Put a piece of paper in the manual feed tray on the front.
4. Print a test page.
If the test page prints to the paper in the manual feed tray, then it is set as the default tray. Go into the printer settings and change it to "auto" or tray 1. If the test page prints to tray 1, but the original document you tried to print (when it got stuck) still won't print, cancel the job. Now, again, put paper in the manual feed tray. Try to print the document again and if it pulls from there, go into page setup of your document and change the setting from "manual" to "auto" or tray 1. Clear the job again (if it's stuck) and you should be able to print again. Hope this helps. This is one of the most common solutions - it happens a lot, especially with documents that are emailed from other people and once they get stuck in the queue, nothing will print (except the test pages directly from the printer, like you describe).
Jun 25, 2008 | Brother HL 5250DN Laser Printer
Photo ink cartridge stuck
I had the same issue. Don't try to force the cartridge out though. After being stuck to the paper, tearing the remainder of the film won't get all of it out of the cartridge. You'll need to print a 'dummy' page to get the last bit to be pulled out and afterwards the printer will automatically release the cartridge allowing it to be pulled out normally.
Apr 21, 2008 | Canon SELPHY CP720 Printer
Paper does not come all the way through the printer
This is more of a workaround than a fix: I open up the front door and use the Face-Down Tray to collect all my printouts.
Aug 09, 2006 | NEC SuperScript 860 Laser Printer
OKI C5200n Laser Printer Logo
182 people viewed this question
Top OKI Office Equipment & Supplies Experts
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
