Question about Xerox WorkCentre PE16 All-In-One Laser Printer
Problem in scanning
When both scanning and copying, part of the copied page or scan area, comes out VERY anemic and almost unreadable. The problem does not exist for incoming faxes.
    President:
  • 2,072 Answers
Your scanner glass, mirrors and lens need to be cleaned.
There is an adjustment you can try.
Press in order. Menu #1934. That will enter diagnostics.
On your menu scroll around to find maintenance, then scroll to Shading adjustment.
Place 5 pieces of paper on the glass and press enter until it runs the shading adjustment. That is the scanner calabration.
That can help. But most likely the mirrors and lass are hazy.
Unlike an old copier where dirty optics showed up as a dark image, dirty scanners see less light reflected from your document and therefore print out what they see which can be streaky, faded and very very poor gray scale.
If you want me to I can send you the steps in disassembling that machine, but it does require pretty much disassembling the machine and that scanner head, you can break the lamp easily.
Posted on Dec 31, 2007
Why is the photocopy and scanned document coming out dark and unreadable?
Hi there, my name is Lisa and I'd be happy to help you with your J6410. I understand your copies and scans appear dark and unreadable. Although you may not be seeing vertical bands, lines, or streaks through your scans and copies, I feel the following document might help you to troubleshoot the issue you have described:
HP Officejet Flatbed Scanner All in Ones With ADFs Vertical Bands Lines or...
Since the issue occurs when you perform both copy and scan tasks the issue is somehow related to the hardware and not to the software. Do you have the printer connected directly to a wall outlet or is it in a surge protector or power bar? Even if you have been using a surge protector/power bar all this time and you feel it is not the cause, please connect it to a wall outlet just so we can eliminate the power source as the root cause. Issues when Connected to an Uninterruptible Power Supply/Power Strip/Surge Protector In this document you will see, ISSUE: Problems or issues may arise when an HP LaserJet series printer is connected to an uninterruptible power supply (UPS), a power strip, or a surge protector
^ This is not limited to Laserjet printers.
If the issue persists, what you can do, is use the following link to create yourself a case number, then call and it may help speed up the call process:
Step 1. Open link: h22207 www2 hp com
Step 2. Enter Product number or select to auto detect
Step 3. Scroll down to "Still need help? Complete the form to select your contact options"
Step 4. Scroll down and click on: HP contact options - click on Get phone number
Case number and phone number appear.
I hope this helps.
I work on behalf of HP.
Jul 12, 2015 | HP Officejet J6410 All-in-one InkJet...
Copy Output all black
Janson; does this problem only occur if you're doing copying via the auto feeder, or also if you lay the paper in manually? The auto feeder uses a small glass opening to the front (or left) of the main flatbed scan area; if there is an issue with that area letting in light, an all black page would result. If you get all black with either type of scan, but regular printing still works, then you may have a dead scan element. Try scanning something to your computer or to an email account to see if normal scanning still works.
Apr 04, 2014 | Dell 2135cn All-In-One Laser Printer
Black vertical lines come and go for scans to computer and copies
I suspect the Document Feeder is not aligned properly and light is leaking in. You will need to have a technician in to check the alignment of the scanner to see if it needs to be readjusted. random black lines on edges usually indicate light leaking into the scan area.
Aug 28, 2017 | Xerox WorkCentre 3220
Xerox Copycentre C20: Copier doesn't scan top 1-3 inches of page. Happens intermittently. When this happens, it moves everything else on page to the top of the copy, cutting out what should be
The document feed rollers may be dirty/worn which is causing the paper to come into the scan area late causing your document cut offs. use a clean, lint-free cloth dampened (not moist) with water and clean the document feed rollers. Confirm they are dry then, try scanning multiple pages and see if they pull through without stalling. If they do, it's time to replace those rollers.
Aug 27, 2017 | Xerox CopyCentre C20 Black and White...
Scan and copy produce a black page
Scan head faulty(which is moving while scanning & copying) , replace it..
Nov 16, 2011 | HP Officejet 6500 Wireless All-in-One...
My officejet pro 8500A prints black vertical lines down the page when I make a copy. I have cleaned and aligned the printheads. What else can I do?
Happened with me too. Turned out to be a small sticky smudge on the ADF glass. That is the smaller glass scan area to the left of the large glass scanning area.
When using the ADF to scan or copy, make sure the smaller glass area is clean along with the rollers.
Oct 05, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
My copy machine is D 861 digita.when i make a copy
If you're using the automatic document feeder (ADF) to scan the document, make sure the ADF scanner area is very clean. This is the area of the platen glass to the right side. Also make sure that you don't have reduction set on the copy size.
Jan 18, 2010 | Canon ImageClass D861 Printer
I have a BROTHER MFC- 8860DN that makes black streaks on copies
If this is only happening with copies and not straight prints, it is possible that the problem is with the scanning unit. Use the soft cloth to clean the scanner area to the left side of the machine where pages are scanned when run through the page feeder. A spec of dust or other debris in this area will appear as a streak along the length of the page.
If it occurs on all prints, You may need to replace the drum or clean the fuser unit.
May 29, 2009 | Brother MFC-8860DN All-In-One Laser...
Help needed on ricoh ft 4015 copier
1-you need to determine if the two are part of the same problem
If the jamming occured first with no signs of copy quality issues then, it depends on where it's jamming. Locate the 1st jammed paper, the one that is furthest towards the exit. this stops all other paper after it. for example if there are papers in the fuser -by the drum and coming out if the tray the problem is most likely in the fuser area. Are the papers being crumbled? or just stop at that location?
2-the half dark copies could be a couple of things
a) the seperation unit is going bad and making the copies rise up against the drum
b)does the lamp that come on to scan the original stay on the whole lenght of the paper or does it turn off half way down the page? if yes the cable that connects to the lamp is probably broken and not making contact at the half way point as it is scanning.
Sep 17, 2008 | Office Equipment & Supplies
1/2 Page Darker
Did you put the old cartridge back in with the same out come? Also when the orginal is being scaned dose the scanning lamp turn off in the middle of a copy?
Mar 05, 2008 | Canon PC981 Copier
Xerox WorkCentre PE16 All-In-One Laser Printer Logo
170 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
